Old 08-03-2006, 04:27 PM
jeffd jeffd is offline
Default FAQ : How to waterproof the ignition.
Question : How can I get the ignition on '99 to '04 200/250/300 water tight?
Answer : So, how does the water get in? The first thing you should know is that there is a vent hole at the bottom of the case that vents to the outside and also lets moisture into the case. In addition, gasgas currently uses a composite cover that can let water into the case at the mating surface.
The seal at the ignition cover can be improved by lapping the mating surface of the cover. Obtain a small and thick piece of plate glass - this will give you a nearly perfect flat surface. Alternatively, the "table" on a drill press or table saw can be used. Lay a piece of extra fine sandpaper on your "very flat surface" and rub the mating surface of the ignition cover against it lightly (in a circular motion) to ensure that the mating surface is completely "flat".
To get a good seal on the gasket, grease the gasket prior to installation along with the rubber plugs. You can also use two gaskets in this location versus one to get a better seal - this will fill voids and give a better seal where the hump is for the counterbalancer (on older models).
As for the hole in the bottom of the case? Some plug it - not sure if this is advised or not. It is a good idea to remove the ignition cover occasionally and spray it down with CRC 2-26 displace the moisture and to combat corrosion. It is not advisable to use WD-40 as components in it have been shown to degrade the insulation in the windings.
On a related topic - dielectric grease can be used to waterproof connections and to avoid corrosion in these connections.
Input on this one?
thanks,
Old 08-03-2006, 07:19 PM
Dave Dave is offline
For sanding, the top of a table saw works well also.
Instead of WD40, it's petroleum base may affect the insulation on the windings, how about recommending CRC 2-26 or a similar product made for the application. The CRC product is available at Home Depot. Here's a link.
http://www.crcindustries.com/ei/cont...=02005%2D6&S=N
Also, the grommet plugging the spare hole in the cover will shrink quite a bit if hit with carb cleaner. You can guess the results.
I wonder if after plugging the bottom vent hole one should add a vent line to the area?
Old 08-04-2006, 08:51 AM
Thanks Dave - I edited the article above to incorporate your input.
What do you suggest using on the rubber plug to "re-expand' it? Armor All?
For the vent - I suppose one could plug the hole on the bottom and add a vent tube to rubber plug in the case - I'll ask Les what he thinks about this.... Or maybe he will just respond directly here.
Old 08-04-2006, 11:03 AM
I ended up using silicone sealant to fill in the gaps on mine.
Initially I was thinking of drilling and tapping the case for 1/8" pipe and threading in an MPT x barbed tube adapter. Using the spare opening as you suggest is a better idea as it wouldn't be permanent.
Old 08-06-2006, 02:45 AM
iancp5's Avatar
iancp5 iancp5 is offline
I took mine off recently forgetting the gasket was there and broke it! Have resealed with blue hylomar without gasket - not sure if that is advisable but was in a hurry to use the bike. Hoping that as this should be a relatively cool, no pressure area it wont matter too much what is used to seal - providing it doesn't eat the plastic of course.
I think when I put a gasket back on I'll try the grease method - that way it should also release without damaging the gasket. I know I should always replace but generally don't in what seem low stress, non-critical locations.
Old 08-09-2006, 10:29 PM
CACTUSREID CACTUSREID is offline
iIn canada we can get a product sold by GM auto dealers that is called silicone emulsion. I'm in the autobody industry, and we use this stuff to swell and revitalize rubber door weatherseals on cars and trucks. It would most likely work well on grommets and seals. it's heavy on the silicone, so I'm sure it's waterproof. it comes in a small 3 oz plastic bottle with a dauber to spread it around.
Waterproof Pants PEB General Discussions & Announcements 7 02-21-2008 11:21 PM
Efi/ignition gevandam General Discussions & Announcements 4 05-29-2007 05:31 PM
04 300EC Ignition changed to DE Ignition Trail Blazer Enduro Engine - 2 stroke 0 01-08-2007 01:48 AM
