Old 04-05-2017, 01:07 PM
andper andper is offline
Default Test speed sensor cable?
Is it possible to use an multimeter to function test The cable? The odo used to woke up when i rotated The front wheel but it doesnt anymore.
Any other ideas on what might be causing this?
Skickat från min SM-T580 via Tapatalk
Old 04-05-2017, 03:33 PM
Odo battery dead?
Old 04-06-2017, 12:56 AM
Anders Anders is offline
Do you still have the bracket with the magnet on the front wheel? On my bike it went missing within the first couple of months.
Old 04-06-2017, 01:15 AM
Tafka Tafka is offline
Use continuity function on the multimeter.
If you have 2 wire speed sensor then it's just usual reed switch. So it has just on-off state. If you bring magnet in front of the sensor and the multimeter starts to peeeeeeeep then the sensor is okay.
Old 04-06-2017, 04:13 AM
Originally Posted by swazi_matt View Post
Odo battery dead?
Just replaced it!
Yepp, it is in place.
Will do.
Odo sensor on B/O TooBadBrad General Discussions & Announcements 2 06-21-2007 07:23 PM
