Old 05-20-2019, 01:47 PM
GG221 GG221 is offline
Default Water pump drain bolt
Looking to replace the cork washer for the water pump drain bolt. Do I need an aluminum washer?
Old 05-20-2019, 04:54 PM
i use a copper washer, i suspect an aluminium one will do the trick as well, just remember to copper slip that bolt, ive had one seize on me
Old 05-20-2019, 06:50 PM
I've used copper too. Any small washer with a bit of crush will do though. I've had the bolts seize too. I usually replace for a hex head.
Old 05-20-2019, 08:25 PM
Ok thanks. What do you think causes it to seize? I would suspect the copper against aluminum? I did find some aluminum washers I will try out
Old 05-20-2019, 09:09 PM
I use part of the power valve cover gasket. Just cut around one of the bolt holes.
Old 05-23-2019, 09:25 PM
not sure, it was not the oem bolt so may have had something to do with that. Used a stainless bolt. the washer was fine
Old 05-24-2019, 01:49 AM
Be careful with the torque. Do it up progressively until it just strips, record that torque setting, then cross thread it in with a good slab of red silicone sealant.
Old 05-24-2019, 06:58 AM
Mine was the stock bolt.. Simple corrosion.. Coolant can be corrosive.. and a small hex head can easily round out with too much force applied.
Old 05-24-2019, 03:06 PM
Yeah had to put a hacksaw cut in mine and use the impact driver to remove it on my old 200 I recall.
Old 05-25-2019, 09:09 PM
shawbagga's Avatar
*Writes this down on paper & nods approvingly*
'18 Gasgas XC250
Coolant doesn?t drain from drain bolt? 2012 250 ec Si176 Enduro Other... 4 11-19-2017 11:03 PM
Coolant drain bolt Lonestar4x4 Enduro Engine - 2 stroke 7 05-24-2012 08:13 AM
oil drain bolt in case jyellard Enduro Engine - 2 stroke 11 10-13-2009 04:39 AM
oil drain bolt crossover ? Brian VT Enduro Engine - 2 stroke 6 08-04-2009 08:11 PM
water pump? nhrider Enduro Engine - 2 stroke 17 12-21-2008 12:05 AM
