Old 03-16-2013, 06:36 AM
andyec300r andyec300r is offline
Default 2009 EC300R 48mm Sachs Fork Seals
Hi There, Is it true that you can fit 2010 honda crf450 fork oil and dust seals to 48mm sachs fork, I have a 2009 ec 300r (racing model) and how much fork oil does every body run. Thanks
Old 03-16-2013, 12:13 PM
I can't answer the first question because I have not had to replace seals since I replaced them with synergyseals (thank god those ss are a real b!tch to fit) in terms of oil I think I am 120mm, but suggest you check the susp settings thread
2003 txt250 Pro
2013 Ossa 280i
Old 03-16-2013, 05:59 PM
Affirmative. The 09 CRF450R onwards (that run the 48mm KYBs - not the showas) will fit the Sachs perfectly. All the seals and bushings will cross over. Back when I last ordered I found the whole kit for $50. Prices have gone up since the Tsnami but if you shop around you might find a bargain.
As for air gap (springs out, fork collapsed) I think specs are between 90-135mm. If you're happy with it as it is now I'd suggest measuring before you drain them out and you'll have a setting to get you back in the ballpark.
Old 03-17-2013, 01:35 AM
Thanks, I'll try the Honda seals and experiment with oil height and once soughted will post my settings on the database
Old 03-18-2013, 10:19 AM
Synergy-Seals Synergy-Seals is offline
Smile
We have the Flex-Seals" and new wipers in stock. They perform perfect....no air build up....cleaner oil......can be removed and reinstalled many times over. Our seals will last years......proven for ten years now.
Rob
www.synergyseals.com
209-938-9726
Being BOLD is BOLD! However, being confident is certain!
Ride with confidence again!
Made in the USA
2009 ec300r fork andyec300r Enduro Suspension 8 04-21-2014 06:12 PM
2009 sachs fork lower pinch bolt Diggs345 Enduro Suspension 2 05-21-2012 01:22 PM
Synery Seals SACHS 18mm shock seals Synergy-Seals Enduro Product Announcements 1 09-30-2011 03:33 PM
2010 Sachs Fork Seals Bradz Enduro Suspension 7 01-04-2011 12:06 PM
Sach Boge 48mm fork info (09 EC300R)??? Keg Enduro Suspension 9 10-13-2008 04:57 AM
