Old 10-19-2014, 08:31 AM
FastFast's Avatar
FastFast FastFast is offline
2013 300XC
+/-5000ft elevation.
40 Pilot.
NEDW on the 3rd clip.
165 Main.
Air screw is 2.5 turns out.
Float Height 8.0mm
50:1 with Opti2 and 93 Octane.
Typically start and end my day in 2nd gear. All my riding is rocky single track switchbacks, hard packed trails, lots of roots and technical riding rather than speed. I've found the changes made to the jetting have really reduced the engine loading up with oil, the bike starts great, warms up in reasonable time, doesn't splooge at all, throttle response is linear and the hit has really been mellowed out. Best for me is with this jetting I have no need to keep tweaking the settings. Within reason, regardless of temperature, elevation, or humidity in my riding area I find these settings to cover all my requirements. Ride and go.
Old 11-03-2014, 06:38 PM
hamilton's Avatar
hamilton hamilton is offline
Default 12 250
Bike year & model = 12 xc250
Temperature (degF) = 60F
Elevation (feet) = sea level
Main jet = 178
Pilot jet = 42
Needle & notch = JD blue needle clip#3
Air screw setting = 1 1/4 out
Throttle valve/slide = 6.5 slide
Results: Carb AS 1 38mm, 40-1 pre-mix, engine mods, FMF gnarly pipe and check point power valve cover.
This setting has taken me a while, think I've tried about every suggested needle on this site. Needed to change slide to get the results I wanted. Nice smooth,strong power from bottom to top.
15 GASGAS EC 250
19 Sherco SE 125R
Old 01-12-2015, 07:31 PM
Simmo737's Avatar
Simmo737 Simmo737 is offline
Bike year & model = 15 300r estart
Carb=AS1 (screw top)
Temperature (degF) = 15-30c
Elevation (feet) = sea level to 1000'
Main jet = 175
Pilot jet = 42
Needle & notch = N3CJ clip#3
Air screw setting = 2 1/2 out
Throttle valve/slide = 7
Float height=16.5mm
As delivered (dealer jetting, not GG). Blubbery but nice to ride and rips from 1/8th up, very tractable but 8.1Km per Litre, did better in sand due to on the needle the whole time. Also lost my breather hose half way and tipped it over on hills a couple of times, so float level and tank loss would not have helped.
Oz
Current. 2015 ec300r estart, 98 RM 125
2013 Ec300r 2011 Ec300e 2009 Husky TE310
1982 XR500 Honda 1981 KE100 Kawasaki
1978 GT80 Yamaha
Old 01-12-2015, 07:35 PM
Simmo737's Avatar
Main jet = 175
Pilot jet = 40
Air screw setting = 1 1/2 out
Float height=18mm
Blubber gone, slightest hint on crack of throttle, much better response, whole rev range crisper. Will evaluate on proper ride soon re range.
Oz
1978 GT80 Yamaha
Old 01-19-2015, 06:13 AM
n_green n_green is offline
Bike year & model = 2014 EC300R E-start
Carb: 38mm PWK ASII carb
Engine: Modified head running 1.3mm squish, 1 x .5mm base gasket. CR unknown, slightly higher then stock - approx 12.5:1.
Temperature (degC) = 25 - 30 degC
50% humidity
Elevation (feet) = 300m.
Main jet = 178
Pilot jet = 40
Leak jet = 85
Needle & notch = N3CJ #3
Air screw setting = 1.4 turns out
Throttle valve/slide = 7 non-notched
Results:
Good strong idle, wicking the throttle response wis close to perfect. There is so much more torque with this jetting, I was lugging it up hills in second that the NEDJ needle would have required first gear for. Whilst there is a slight blubber under load its not too bad and doesn't load up too much. The top end is so much better using the N3 needle, from low revs in 4th gear it rolls on smooth and predictable before exploding into an awesome top end. There is a bit of a lull before it comes onto the pipe, I have a feeling half a clip leaner would do the trick, will experiment another time.
Fuel use was 4.5l for 58k's = 12.8k's per Litre.
http://youtu.be/nsFQfvtA12s
Current:
2014 Gas Gas EC300R
_____________________________________________
Previous:
2011 Gas Gas EC300 ELC
2004 KTM 300 EXC
Old 01-21-2015, 10:39 PM
jpgibson's Avatar
jpgibson jpgibson is offline
Bronze Level Site Supporter
Bike year & model = 2013 EC 300R with e start
Temperature (degF) =26C = 80 oddF
Elevation (feet) =less than 500ft
Main jet = 175
Pilot jet =40
Needle & notch =N3CJ #3
Air screw setting =1.5
Throttle valve/slide =standard ( 7 i think)
Results:no bloody good!
Bike was running OK, with the 0-1/8 splutter.With the 40PJ I could NOT get it to idle at all.I had this problem with my 2010 too.I put the 42 back in-> all good.
Looks like I'll have to accept the slightly annoying splutter/burble and never touch it again!
So, what works is:
Bike year & model = 2013 GG EC 300R with e start
Temperature (degF) =80
Elevation (feet) =500
Main jet = 175
Pilot jet =42
Needle & notch =N3CJ#3
Throttle valve/slide =7
Results:back to its normal self.End of quest.
Old 01-23-2015, 10:29 PM
jpgibson's Avatar
hold on a minute gibbo...quest not over!
Bike year & model = 2013 300 EC Race/E
Temperature (degF) =86
Elevation (feet) =300
Main jet = 175
Pilot jet =40
Needle & notch =NECW#3
Results:Was only around the block a few times, but...Started( no choke, but then it is 30 oddC), instantly and settled into an idle immediately.Warmed bike up and blatted around the streets. Still a bit of burble off the bottom BUT seemed smoother and had a pretty decent hit up top.
Why an NECW? Cos I've got one of them- the others being N3EG x2, N3CJ, NECW,N1EG and I thought ( well, after reading n_green, jakobi's posts) if I go richer on the straight section , I'd better lean the PJ ( which is not what I did the other day-N3CJ and swapped a 42 for a 40-no good).
Hopefully take it for a ride in next couple of days.
Edit: went for a ride today: 20 C , pouring with rain.NECW#3,40 PJ, AS 1.5, main 175. Started, idled and lugged great. The , after a couple of hours, the idle started to hand.Fiddled with AS ( turned it in a bit), settled.
Got home and cleaned her, thought I might lower the needle and when I took the slide out, it was a bit 'stuck'- white greasy stuff on the back of it.mmmm.Had a look at the airfilter, was a bit wet.So I think I may have taken a bit of water on board!All cleaned out, new filter. Also had a look at the plug, it was dry but black ( mostly).Not surprising as I tootled around most of the time, dont even think I got on the pipe!
Old 01-30-2015, 08:04 PM
jpgibson's Avatar
Bike year & model = 2013 300R/E
Temperature (degF) =70
Elevation (feet) =200
Main jet = 175
Pilot jet =42
Needle & notch =NECW #2
Throttle valve:7
Results:Changed the PJ to a 42 as I was 1 or thereabouts turns out on the AS.Idle kept hanging with the 40.Put in the 42 and it needed a bit more out on the AS and was a bit rich.So, I dropped the needle to #2 ( from 3).
Admittedly I only rode round the block a few times ( sorry Stanmore-ians) but it felt good.Very smooth.
Oh JG's top tip: if you havent got a air compressor, a bike pump with a presta valve attachment is perfect for blowing air through the PJ!
Old 02-04-2015, 12:13 AM
Simmo737's Avatar
Temperature = 15-30c
Main jet = 175
Pilot jet = 38
Needle & notch = N3CJ clip#2
Float height=18mm
Power Valve=stock
Maxima 927 40:1
This jetting is unreal. You could probably just squeeze a 35 in but you'd lose the torque. Now to adjust the pipe hit with the pv.
Oz
1978 GT80 Yamaha
Old 02-04-2015, 01:16 AM
BSM2 BSM2 is offline
What does mean "Throttle valve/slide = 7" ??
The jetting database needs your help! MattR General Discussions & Announcements 4 10-18-2017 05:34 PM
JD Jetting settings for linear power delivery? SpeedyManiac Enduro Intake/Carburetion - 2 stroke 5 04-06-2010 06:17 PM
Modification/Aftermarket Database SpeedyManiac Enduro Product Reviews 4 02-04-2009 07:09 AM
Jetting Database Announcement MattR General Discussions & Announcements 0 12-18-2008 08:58 PM
Jetting Database Summary MattR Enduro Intake/Carburetion - 2 stroke 0 12-18-2008 08:36 PM
