#81
I fear that you may be confusing the pilot jet circuit with the jet needle/needle jet circuit, in where it is too rich. If you have the throttle stop screw screwed in too far, the raised slide (and resulting raised jet needle) can effectively bypass much of the pilot jet circuit.
(IMO... The pilot jet controls from 0 to 1/8 throttle. The jet needle/needle jet circuit controls from 1/8 to 3/8 throttle; with the slide affecting everything; and the main jet influencing things more as the throttle opens more, and controlling the jetting from 1/2 to WFO.) Regardless, the #7 slide will definitely lean things out a bit. Good Riding and Jetting! Jim Good Riding!
Jim Cook Smackover Racing Team LAGNAF '11 Gas Gas EC250 (primary ride) '06 Gas Gas DE300 2004 Gas Gas TXT300 Pro '94 Husaberg FE350 '86 Yamaha IT200 '86 Honda TRL200 Reflex '04 KTM 525EXC (soon to be dual sported) Several others, including project bikes, Deb's bike, and a fleet of grandkids' bikes Let's go riding! http://www.jebruns.com/Wudi19/wudi19.html http://www.ahrma.org/schedules-results/cross-country/ |
#82
Jim,
What's driving me crazy is that I jet it, it runs well, then it changes on its own! I can't decide if it's my imagination or there is something else going on. How much does the weather effect it? The temp has only dropped 5-10 deg but it's gone from dry air to very wet and damp. |
#83
It's a compromise, but you should be able to come up with a compromise which will work in a variety of situations is a fairly usable range of temperatures and humidity. One more thing.... I never try to experiment with jetting unless I have fresh packing in the silencer. Dirty silencer packing throws the formula way off. Good Riding! Jim
#84
throwin a thought out there, could ur needle seat be worn? from what ive read a worn needle seat will make ur jetting next to impossible.
03 ec250 hyde skidplate, cycra handguads, protaper contours "what? it seemed like a good idea at the time!" |
#85
Could be. Maybe I should bite the bullet and get a new carb. It's almost as cheap as sending it to RB from the here. Although didn't I hear that some of the older Keihin allowed replacement of the seat? Bet no-one in the UK stocks them though. I'm waiting for the #7 slide at the moment. I think the fact I'm using a 35mm doesn't help, not sure what other bikes it's used on. I can get a new 36mm for £110 though.
#86
i have been completely happy with the 36mm carb. my jetting has been pretty stable 50-90 degree weather. i've felt no need to tinker with it once i got it close. it runs way better than it ever did with the 38mm carb. and it truly idles, without cranking the idle screw in/throttle adjuster... and it's way snappier off the bottom.
07 ec300 was 00 xc200 now a 00 xc300. now parting out. 99 ec300 (now a pile of parts which are for sale) Stainless Cycle - Motorcycle Bolt Kits www.stainlesscycle.com |
#87
Any of you guys with the 200's tried adding the 10mm spacer to the exhaust flange like Go Fasters recommended to help low end power?
Maybe Go Fasters (or Scotties) could fab up a kit if it works so good?
07 EC 300 (under 500 miles, selling soon) 97 KTM 250 EXC (sold) 2016 Trek Remedy 29er |
#88
i run the ltr style pv cover, which i believe achieves the exact same thing as the 10mm spacer. i also have a 9 oz flywheel weight on it.
#89
+1 Same here
#90
Maybe try and get ahold of a newer 200 specific pipe. If someone has one it would be interesting to see the dimmensional differences.
LTR or JD Jetting Kit | Elvis74 | Enduro Intake/Carburetion - 2 stroke | 7 | 04-08-2010 02:49 PM |
04 ec 300 Jetting | lordfeyr | Enduro Intake/Carburetion - 2 stroke | 12 | 01-26-2010 03:16 AM |
Need help jetting an 06 EC 250 | piperpilot12w | Enduro Intake/Carburetion - 2 stroke | 3 | 11-16-2008 11:19 PM |
jetting help for 05 300 please... | mackmack | Enduro Intake/Carburetion - 2 stroke | 5 | 09-03-2007 05:10 PM |
06 300 jetting | fury1 | Enduro Intake/Carburetion - 2 stroke | 1 | 07-31-2007 06:37 AM |
