What are the differences between Air Strikers I and II?
I've read several times that the 2011's are using Air Striker II carbs. I've searched Sudco and Google and can't seem to find any substantive info on the differences. The only thing obvious to me is the screw-off cap is gone.
Does anyone have any good info?
'11 Husky CR150, '11 GasGas XC 300-E, '11 Kawasaki KX250F, '71 Hodaka ACE 100B+ |
From the memory bank (somewhat foggy) - The tops obviously, and the bowls as well (AS II slightly tidier), shorter front to rear ... different jetting too - typically 1-2 sizes larger on the pilot and 1-2 sizes smaller on the main.
My 08 ec250 had the old style carb with the round screw off slide. My 2010 ec250 race has a slide that is held in with screws. I could not see any difference between these carbs when I had them side by side except those I just mentioned. Also, the performance of the two seemed idenitcal.
Also, both have 38mm carbs. I am not sure why people are listing that there was a smaller carb from 2008 to 2010. I am not aware of any. |
Float bowl is shallower on AS2, good luck setting float level to old spec.
carbs
Here is what I have found so far by my experience. I have a 2010 SD and a friend has a standard 300 ec both are 300s. Mine has ASII his ASI. THEY WILL NOT RUN THE SAME WITH THE SAME JETS OR NEEDLES. My best performance with the ASII is with a JD jetting kit for a yz 250 but ask him the extra needle between the red and blue tip because its a 1/2 degree leaner than the blue tip. Run it 3rd position 38 pilot 170 main air screw 3/4 out. I ride 1500-2500 feet or u can run a KTM N3EH 3rd position same jets. ASI ran best with N1EF 2nd position 45 pilot 180 main
2011 Nambotin 2010 300 Six Days 2008 Raga 2008 250 xc KTM 2007 200 xc KTM To many KTM's to list 1983 175 IT Yamaha 1995 200 KDX Kawasaki |
After reading on here about the differences between ASI and ASII carbs and the difficulties of jetting the new 2011's I went out and measured the bore on my 2011 EC250. Guess what? The new carbs are 36mm not 38mm that were on the previous bikes. It's also stamped 36 on the top piece that holds the slide. Mine is a 250, but I would think the 300 would have the same.
GG used the same jetting they previously put in the 38's, in the new 36's. This would explain why no one can get them to run right. They're too rich. My best setting so far is : 40 pilot 1 1/2 AS CCK needle 2nd clip (N3EW 3rd also worked well) 170 main 6.5 slide It's still pretty cold here. 25-40 degrees so I know when it warms up I'll have to go leaner than these settings. |
I have a 2011 EC300 and mine is stamped 38 on top of the carb.
2011 EC300 2013 TXT300 Factory Replica 2014 Polaris Assault 2004 Snowhawk 600H.O. |
I thought mine was stamped 38... then I got a flashlight and inspection mirror and saw that the "38" was actually a 36.
I suppose it's remotely possible, but somehow I doubt that GasGas would randomly install 36 carbs on some 11's and 38's on others. If they did, it would be a MAJOR F-up.
Strange that GG put 36's on some of the 2011's and 38's on others. The picture clearly shows that yours is indeed a 38. Mine was stamped 36, but I wanted to be sure so I measured the bore with telescoping gauges and a 1"-2" micrometer. Result, 1.418". Divide that by 0.03937= 36.
I suppose this is would fall along the same GG policy that some of the 2011's come with Sachs forks/ Sachs shocks and others come with Zoke forks/ Ohlins shocks. A good percentage of guys don't really understand jetting principles. Jetting is viewed as a black art by a lot of riders. It takes experience to get it right. If both the 36's and the 38's come with the same jetting installed from the factory it sure is going to make it tough for Joe Average customer to jet his new bike effectively. |
300 2T Differences between 08' and 2011 ?? | husley | General Discussions & Announcements | 11 | 12-23-2010 10:31 AM |
´08 and ´09 differences? | vavido | General Discussions & Announcements | 3 | 11-10-2008 09:20 AM |
head differences 03-05 450? | Motarded1 | Enduro Engine 4 stroke (including EFI & Exhaust) | 3 | 05-12-2008 01:02 AM |
head differences 03-05 450? | Motarded1 | Enduro Engine 4 stroke (including EFI & Exhaust) | 0 | 05-03-2008 07:43 PM |
Differences between DE and EC models | ScottyR | General Discussions & Announcements | 38 | 02-13-2007 06:40 PM |
