Old 07-14-2020, 07:40 AM
Originally Posted by Johanv View Post
Hi, running a 50:1 ratio on 95 unleaded fuel. Read a reply that over oiling an air filter can also result in killing the plug- had a look at my air filter and I think I was a bit eager on the air filter oil spray. When I removed the carb I also took out the reed block-its a boyesen block and the previous owner tried to modify another brand reed valves in there with some modification on the holding plate- the reed tips was also open- will replace them. What is the correct fuel? Should I rather use 93 unleaded?
No, stay with 95 unleaded and 50:1 but get a correct spark plug.
Old 07-14-2020, 08:58 AM
Johanv Johanv is offline
I will give it a shot- thanks
Old 07-21-2020, 06:46 AM
Default Spark Plug Issue
Well, I replaced the reed valves with that of a Banshee ( Carbon Fibre) and now my bike runs like a beast. Will check the plug cap if it fouls again and also be a bit leaner on the hand when applying air filter oil. Thanks for the replies and advice.
Old 08-10-2020, 06:22 PM
motorhead's Avatar
motorhead motorhead is offline
Singletrack/Low RPM'S = BPR7ES
P - projected tip, 7 - one step hotter than 8, =Less plug fouling💡
TeamFlannelOutdoors-somewhere South of I80
05' Gas Gas 300 DE
(Son's) 22' Rieju MR300 80th Anniversary Edition. 02' Gas Gas 250 XC
Moto Farm motor and suspension service 309 310 2540 leave a message
www.halls-cycles.com
Old 08-11-2020, 03:57 PM
Sorry, but fighting plug fouling with a hotter spark is not the right way. If you have toothache you can take a painkiller, it may help. But it is not the final solution.
Spark plug eviljim Enduro Engine - 2 stroke 4 01-06-2013 02:35 PM
Spark Plug Gap savage sausage Enduro Engine - 2 stroke 3 04-15-2012 11:54 AM
Spark plug? Pepperami Enduro Engine - 2 stroke 3 06-28-2011 01:49 PM
Spark Plug Crankin04 Enduro Engine 4 stroke (including EFI & Exhaust) 18 03-02-2011 02:50 PM
Spark plug gasgas125sm08 Enduro Engine - 2 stroke 0 03-08-2010 09:42 AM
