300 base gasket choices?
So I think I learning that there are different base gasket thicknesses available for my 10' 300?
If so, I would like some more bottom end grunt as I am rarely on the revs Thanks! J
2015 KTM 450 XCW 2014 350 XCF Wife's 2009 200 ec. Loving it 2007 Beta Rev 3 270 2007 KTM 200 XC Wife's Public Lands belong to the Public |
All bikes are different, and require a different stack for the same/similar characteristics. My 300, I believe I have 2 thick, and 1 thin gasket. The amount of gaskets do not matter, it is how they line up in comparison to the piston in bottom dead center. I put the piston at BDC and made it level with the exhaust port.
This made my bike into a torque monster. It is so linear, it is unreal. I just twist the throttle and it hooks up and lugs like no other.
2013 GasGas 300 2004 GasGas 200 2011 GasGas 300 Ortonville Minnesota |
They come in 0.15, 0.30, and 0.50mm versions, so mix and match to your heart's content. Just remember your compression is changing along with your port timing when you change the stack.
There are Thick which is .5 MM, a .3 and a .15. You can get it dialed in really well with the different gaskets. All are stack-able to your liking and need.
Compression ratio changes, and so does your squish clearance. A stock head will have a decent clearance to start with so moving the cylinder lower will tighten up that clearance, increase compression, and move power curve downwards (both through comp and port timing).
Setting the piston edge flush with the base of the exhaust port at bdc is your configuration for peak HP. Usually takes a bit from the bottom and stuffs it up top. Before just slip slop slapping any old stack in there I'd think about what you want to achieve. Then set the stack, and then have someone machine the head to suit that stack and your purpose and fuels. I wouldn't drop 1mm of gaskets out without checking the port timing and squish clearance first. I'd probably CC everything before pulling it down to calc the CR too. |
Thanks
Thanks for everyone's input, very informative. But I am missing a part of the puzzle:
I would like more low end and I am willing to sacrifice top end for torque. In order to do this I would use a thinner or thicker base gasket set (relative to the existing/stock)? If I get a Wossner top end kit will it have all the gasket thickness I need to chose from or would I order them seperate from gofasters, etc? Thank! J
I use stock gaskets and Wossner piston kits. All that's missing then is the wrist pin bearing which we also have.
PlusOnePerformance
Hmmm
Okie Dokie
How would thicker vs thinner base gasket effect performance?
Dustin and Jake pretty much nailed it. If you pile gaskets on you'll likely need to have the head re-done.
Most of the 300s I've seen have been 0.5mm stock. PlusOnePerformance
Confused yet? Thick gasket stack = top end, thin stack = bottom end (all other things being equal). Make sure to confirm your squish is no less than 1.2mm and no more than 1.8mm when all is said and done. Anything outside of that needs some professional help cutting the head.
Phil (New bike pending...) |
Base Gasket re-use? | motogroove | Enduro Engine - 2 stroke | 5 | 06-26-2011 07:56 PM |
!!! Help with Base gasket thickness !!! | timlh | Enduro Engine - 2 stroke | 1 | 05-14-2009 07:58 PM |
thinner base gasket | fullthrottle | Enduro Intake/Carburetion - 2 stroke | 4 | 06-01-2008 08:09 AM |
Base gasket | Ud_luz | Enduro Engine - 2 stroke | 21 | 05-09-2008 07:38 AM |
Base Gasket | gtsnowcrack | Enduro Engine - 2 stroke | 6 | 09-09-2006 05:43 AM |
