Old 06-24-2016, 05:50 PM
Olliesherman Olliesherman is offline
Today I did the fork seals on my 2009 ec 300. I haven't actually posted what I've done before. I've only owned the bike for about a month in that time I've done chain and sprockets front pads rear wheel bearings swapped out the shock spring for a stiffer one. Halfway through doing all this i took the exhaust off to check the powervalve tension and looks up the port to see the piston was in a bad bad way. Stripped it down to find out at some point someone had done a piston change and put it in the wrong way so the rings had caught up on the exhaust port mashing up the rings and my barrel. So that was off new vertex piston kit and the barrel sent off for repair and replate. Now I finally have the bike as I want. Loads of compression sounds amazing pulls amazing so nice to ride. Oh and swapped out the brake banjo for a solid one way nicer feel to the brake now.
Old 06-25-2016, 04:52 AM
I washed mine for the third time since racing it 2 weekends ago. Nasty mud caked into every nook and cranny.
Todays wash was stripped right back. No tank, no seat, rear fender removed. Poor bike was looking used prior. Looks good with a spray of silicone though
Old 06-25-2016, 08:28 PM
gasser's Avatar
gasser gasser is offline
My 2011 frame is off to the powdercoaters for a new paint job. While I flirted with changing my bikes color to green or yellow I eventually settled with keeping it red. Frame will be a ruby red over silver metallic.
Old 06-26-2016, 09:07 PM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
Ken,
Post photos when you get it back, and again when you get it finished.
I want to see it.
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Old 07-02-2016, 09:46 AM
papa_j papa_j is offline
Took it out and rode it in Sipapu New Mexico.
Old 07-05-2016, 09:34 AM
stabak's Avatar
stabak stabak is offline
scored a new seat cover....
EC250 2019
Old 07-05-2016, 06:13 PM
hadfield4wd hadfield4wd is offline
Rode the piss out of it!!
Matt
1999 GG EC 250 Six Days
1999 Cagiva Gran Canyon
2001 Aprilia Falco
2001 Triumph Speed Triple for my 20 year old
2000 GG XC250 for my 20 year old
2003 Honda Rancher 350 for the wife
Old 07-06-2016, 08:40 PM
muddertrucker muddertrucker is offline
New rear tire (at81) with tubliss system.
Old 07-08-2016, 08:09 AM
Anders's Avatar
Anders Anders is offline
I tried to straighten my RHS radiator. I also installed radiator guards from Bulletproof Designs.
I went from this:
to this:
Not perfect, but at least it fits inside the Bulletproof Designs radiator guard.
I filled it and went for a short ride in 1st gear around the house. Couldn't spot any leaks.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 07-17-2016, 05:13 PM
RockefellerGG RockefellerGG is offline
Today I rode my EC250 for the first time since installing the KYB SSS forks. WHY DID I WAIT SO LONG!!! They are amazing. Now I need to tune up my Ohlins shock.
2005 GG EC250 - Smart Carb, Rekluse Core EXP3.0, KYBSSS Forks, LHRB
2011 GG EC300
2008 KTM 300 XCW - Rekluse, LHRB
DNF today Pepperami Enduro Chassis & Body 6 09-18-2013 11:59 AM
Got my first GG today! RonMexico General Discussions & Announcements 6 02-19-2011 12:39 PM
Went Riding Today and..... coolum74 Enduro Engine 4 stroke (including EFI & Exhaust) 2 11-30-2008 01:12 PM
HELP! I tried to use my gasgas as a jet ski today! sammyj18 General Discussions & Announcements 19 11-21-2008 08:01 PM
SHNF From Today Boomhauer Pictures & Videos 13 10-30-2007 04:18 PM
