250/300 EC engine cases
Can anyone tell me if the engine cases on the 250 & 300EC are interchangeable?
As far as I'm aware, there are changes between come years though
2006 EC300 Enduro - Ignitech CDI - 38/NECW#2/165 FMF gnarly, FMF shorty, .50 front 5.7 rear 2016 RM-Z450 |
same
external and internally the same cases, crank & rod 250-300 cylinder and head different .200 is a slightly different animal but still similar in most ways.
There is a difference in mounting from early appx pre 04? after that I believe the same up til now. Stoby |
Sent fra min E5603 via Tapatalk
Anders "So you know, that you're over the hill when your mind makes a promise that your body can't fill" (Little Feat: Old Folks Boogie) 2015 EC200 Racing: TE bars, Rekluse Core Exp 3.0, 38mm Lectron & Ohlins S3 steering damper 2006 EC200: 2011 plastics, Rekluse Z-Start, revalved KYB forks & Scotts steering damper 1998 Bimota Supermono 1986 Duc Mille S2 1975 Guzzi sidecar hack 1961 Morini Corsaro 125 etc |
Sandblasted Engine Cases & Pipe | savage sausage | Enduro Engine - 2 stroke | 11 | 02-04-2016 03:35 AM |
Die Cast engine cases | Hawkeye | Enduro Engine - 2 stroke | 3 | 08-29-2011 09:36 PM |
