Raising the rear
Hey guys , quick question . Is there anyway I could maybe raise the rear of my 09 ec125 slightly ? I'm 6ft1 & feel like I could do with it being a tad taller , it's quite a bit lower than. My mates ktm's
Well the correct first step is to increase the preload.
And check there isn't collapsed bearings by lifting the wheel and feeling for play. About 1cm is OK. Then there is tall seat foam. Desperate measures would be shorter dogbones. Might be worth checking if someone shorter has put longer ones on. Will have a number cast on them like 122. .
Can you install a larger and taller tire? Verify it does not have lowering dog-bone links in the suspension.
Raising the bars.... | r00zter | Enduro Chassis & Body | 11 | 04-27-2012 07:01 PM |
Raising oil level 2011 forks? | fire1998 | Enduro Suspension | 23 | 10-10-2011 11:51 AM |
EPA considering raising ethanol to 15% | eff | General Discussions & Announcements | 17 | 06-01-2011 11:27 PM |
Brent Martell : ISDE Fund Raising | webmaster | General Discussions & Announcements | 7 | 05-31-2011 10:16 AM |
GasGasRider.org T-shirts & fund raising | coolum74 | Suggestion Box | 12 | 03-01-2009 02:41 AM |
