Old 01-16-2018, 01:37 AM
expirmininkas expirmininkas is offline
Hi,
Thank you for reply. Well, I took the bike to the forest lately And when it is running, it "wants to go up on wheelie" on the 3rd gear. However, if for any reason engine shuts down, it is very difficult to start it again - it doesnt not start, later it fires, and if I open full throttle during starting process, it seems like starter stops its work (to be short: opening full throttle kills starting).
If I wait for a ~ minute, in mostly cases I can start the engine. Maybe it is normal for GG?
I remember having Yamaha XT660R - I could start it again after engine shutting down immediately during riding, even when I am still on the bike
Old 01-16-2018, 08:57 AM
Tafka Tafka is offline
Yeah, the hard starting sounds familiar
If you try to start, are you touching the throttle? If yes then DON'T!
There's two ways to start GG:
1) ignition ON, wait until the fuelpump primes and then hit the start button.
2) If after 2-3 tries no luck then: ignition on, fuel pump primes and then turn the throttle fully open and then hit the start button.
Moving the throttle during starting is NO-NO
Is your starter okay? I had also some problem when starter clutch was slipping....
But yeah, injector and TPS could be also issue
Old 01-17-2018, 12:53 AM
Thank you!
So, throttle should be opened beforing pushing starting button, if the bike failed to start in 2-3 times?
Old 01-17-2018, 04:24 AM
Yep, hold full throttle and then push the start button. Worked for me
Old 01-19-2018, 12:27 AM
Thank you again!!!
BTW, yesterday I've done compression test, and the reading was 0.5 Mpa (~ 72.5 psi or 5 bar). Do you know, whether is OK? I cannot find info about it.....
And I've found the info (in workshop manual):
The correct compression of a cylinder indicates that
the internal conditions are good. The decision to
inspect a cylinder is based on the results that we
obtain when measuring the cylinder compression.
Compression verification should be included in
concessionaire inspections.
DATA Compression:
Standard: 1000 Kpa (10.0 Kgf/cm2).
So the journey to find out the problem (valve clearance, pisto, rings, etc.) begins....
Old 01-22-2018, 12:23 AM
Did you measure the compression correctly? I mean cranked the engine until the pressure didn't rise anymore? Usually it helps to hold throttle fully open.
5bar is too low.
Old 01-22-2018, 02:55 AM
Yes, I did measurement with throttle fully open. And there may be two things:
1. My measurement instrumet is too old/faulty, or
2. Compression is too low, which is very possible, as I have problems with starting.
I've found somebody that repais GG in Lithuania, so, I'll take the bike to them to do the valve clearance checking.
Old 01-22-2018, 06:09 AM
If you need any parts then contact with Antonio at Motocrosscenter. If i remember correctly then you can get piston from W?ssner but other parts are hard to find. I got good deal from Antonio...original piston/cylinder etc.
Let's hope you need only piston change
Old 01-23-2018, 01:13 AM
VilluEST VilluEST is offline
Try and squirt some engine oil in from spark plug hole. If the reading then jumps up to normal or even more, then you have a worn engine. Also, you can test your pressure gauge against some other manometer (tire for ex).
Old 01-23-2018, 01:43 AM
Hi,
Thank you for the advice, I'll try things you've suggested
400 FSE will not idle when hot Gordonian Enduro Engine 4 stroke (including EFI & Exhaust) 5 08-30-2016 09:49 AM
'05 450 FSE Gear Stick/Engine Stall... bhambaker Enduro Engine 4 stroke (including EFI & Exhaust) 9 04-07-2016 10:50 PM
ec 300 2005 won't rev high nor idle... hannesd Enduro Engine - 2 stroke 23 12-17-2012 01:52 AM
300 won't idle. Please help!! stemplin Enduro Intake/Carburetion - 2 stroke 32 04-05-2012 07:28 AM
can,t get idle up geno Enduro Intake/Carburetion - 2 stroke 1 04-18-2010 08:49 PM
