Go Back   Rieju & GasGas Legacy Riders Club Forum > General Forums > Suggestion Box
Suggestion Box Help us make this place the best it can be!
Old 04-29-2016, 04:16 AM
barossi73's Avatar
Default New post 24hr rollover
Id like to see any new post stay up for 24 or 48hrs.at present sometimes a post or reply is only up for a few hrs at most before it gets rolled over.as this is an international site with broadly different timezones it makes sense to use a timeframe which gives each post enough time to be viewed by all frequent members.thanks,otherwise great site
2013 ec200r
Old 04-29-2016, 11:32 AM
poelinca's Avatar
poelinca poelinca is offline
Good point.
If we are at it, make it "account based" instead of "session based". I'm logging in from different computers during the day, and the same posts i have read on a browser/pc are being highlighted on another one witch creates confusion.
'14 EC300
Old 04-29-2016, 04:30 PM
webmaster's Avatar
Administrator
I will check and see if it is configurable in any way.
thanks,
Old 04-29-2016, 04:36 PM
webmaster's Avatar
Administrator
We have the following options :
This option controls how threads and forums are marked as read.
1. Inactivity/Cookie Based - once a user has been inactive for a certain amount of time (the value of the session timeout option) all threads and forums are considered read. Individual threads are marked as read within a session via cookies.
This option is how all versions of vBulletin before 3.5 functioned.
2. Database (no automatic forum marking) - this option uses the database to store thread and forum read times. This allows accurate read markers to be kept indefinitely. However, in order for a forum to be marked read when all threads are read, the user must view the list of threads for that forum.
This option is more space and processor intensive than inactivity-based marking.
3. Database (automatic forum marking) - this option is the same as a previous option, but forums are automatically marked as read when the last new thread is read.
This is the most usable option for end users, but most processor intensive.
It was previously set to option #1 - and I have changed it to option #3.
Since it was previously dependent on cookie settings for your browser - you may have seen different durations, etc. depending on device, etc.
Old 04-30-2016, 04:20 AM
barossi73's Avatar
Thanks for the clarification,much appreciated
2013 ec200r
Old 04-30-2016, 05:02 AM
I'm not a fan of how its running now Jeff. Preferred cookies in that I could click new posts and anything new would present at the top. Once read it would go from bold to normal. With the current setup once I read something it's no longer listed when using "new posts".
Old 04-30-2016, 06:24 AM
barossi73's Avatar
Talking
Yeah,thats a problem alright
Sorry,wasnt tryin to upset the status quo which works pretty well.just had a couple occasions where a post vanished from 'new posts' to main forums within a couple hrs,got me curious i guess!(i freq check new posts,but only trawl main forums when req,wondered what id missed)
Seems the internals of it all work a little different than i had imagined...
Il take a look at my browser settings and go back to playin with spanners...
As you were
2013 ec200r
Old 04-30-2016, 07:06 AM
barossi73's Avatar
Seems i may have found what i was looking for in the site options
User cp/edit options/thread display options/default thread age cutoff/2days
Does this setting apply to just the 'new posts'?
Edit-it affects all main categories,older threads dissapear
(Feeling a bit of a dickhead for wasting your time,if you ever get to nz,the first jug is on me)
2013 ec200r
Old 04-30-2016, 07:34 AM
It's a good and useful discussion. No need for apologies mate!
When using option 1. I don't believe their is a time cut-off for new posts.
As Jeff said, it's cookie based which means that when you log in it opens a session and then on the client side it retains which threads have been read and which have not. When the session either times out (based on a determined time frame) or when you log out it removes all the data, and anything regardless of if you read it or not will no longer show when searching for new posts.
You can miss things this way, especially if you get distracted and the session times out before reading things. My work around in this event is simply to occassionally go to quick links and display "today's posts". Good way to pickup threads that may have snuck past the new posts search (as per reasons above).
Old 04-30-2016, 08:45 AM
barossi73's Avatar
Gotcha,clear as mud!
So for eg if i post a reply then reread/edit my own reply it drops off my new posts.however it stays in other members new posts until they read it,or logout without reading it?then it drops to main forum yes?(in #1 at least)
2013 ec200r
My first post. Adss General Discussions & Announcements 1 05-29-2013 03:52 PM
PHOTOS from Perry Mountain 24hr Challenge Photog Pictures & Videos 0 07-11-2008 01:05 PM
24hr Challenge Alabama- roll call gasgasman Off Road Racer's Corner 11 06-09-2008 05:49 PM
24hr race Alabama-Pit stuff. gasgasman Off Road Racer's Corner 2 04-28-2008 07:55 PM
