Old 04-16-2016, 10:53 AM
Martin-EC300's Avatar
Martin-EC300 Martin-EC300 is offline
Default Is this the dreaded PV rattle??
Firstly thanks to all who helped me with advice in my previous thread, the bike is now back together and is running rather sweet on a zero hour piston... That is until I ride it
What d'you guys think.... It sure as hell ain't the chain..lol
https://vimeo.com/163089683
Old 04-16-2016, 10:55 AM
https://vimeo.com/163090099
Old 04-16-2016, 02:21 PM
Capz85 Capz85 is offline
Sounds very similar to the noise ive been getting, richening the jetting has taken the noise away.
When mine was doing it as loud as that it was scuffing the bore, pull the pipe off and check it's not doing the same to yours
Hopefully it is the pv having a good rattle, have you looked at the pv rod, sometimes they rattle on the cylinder, just a case of tweaking it so it sits clear
Old 04-16-2016, 02:53 PM
Thanks...Actually the rod was extremely close (maybe even touching)
It did it before the new piston but not this loud, cylinder bore is fine for now
Old 04-16-2016, 03:27 PM
Hopefully it's just that
Old 04-16-2016, 06:38 PM
Why isn't it the chain? What have you done to rule it out?
What happens if you pull the clutch when it's doing this? Does it stop right away? What happens if you click up/down a gear? Do you have a bash plate on the bike?
Old 04-16-2016, 07:12 PM
hamilton's Avatar
hamilton hamilton is offline
Yep, sounds like chain slap. If your engine sounds that bad you won't be riding far. btw your riding on the wrong side of the road.
15 GASGAS EC 250
19 Sherco SE 125R
Old 04-16-2016, 08:58 PM
barossi73's Avatar
Eliminate chainslap as the cause first,retension or try dragging rear brake at the same time as it starts to rattle.
Could be the powervalve arm as you have had the topend off.remove header pipe,remove rhs pv cover,refit pipe and start engine.bring revs up to problem area and watch the arm closely..
2013 ec200r
Old 04-16-2016, 10:24 PM
poelinca's Avatar
poelinca poelinca is offline
Sounds like chain slap to me.
'14 EC300
Old 04-17-2016, 03:02 PM
Well I feel really stupid! I was 100% sure the wasn't the chain, however I completely forgot I went down a tooth on the front while the bike was in bits ... I'll get my coat
rattle under load Barton Enduro Engine - 2 stroke 12 04-27-2014 11:52 AM
EC 250 New bike rattle! justsam Enduro Engine - 2 stroke 4 01-14-2014 10:19 PM
Dreaded 2003 fse450 build czugun Enduro Engine 4 stroke (including EFI & Exhaust) 1 07-04-2013 07:55 AM
rattle Rabbitist General Discussions & Announcements 4 09-07-2011 08:10 PM
clutch rattle? jostby Enduro Engine - 2 stroke 0 02-25-2007 05:01 PM
