Go Back   Rieju & GasGas Legacy Riders Club Forum > Classified Advertisements > Parts
Parts New/Used Components and All Bike Part Outs
Old 05-02-2018, 10:40 PM
gasman88 gasman88 is offline
Even if you hack off the battery box? I have no use for a battery. I don't mind upgrading plastics and a seat. Just wanted to go cheap because my subframe is definitely out of wack.very hard to fit everything where it should be.
Old 05-03-2018, 08:09 AM
nknudsen's Avatar
nknudsen nknudsen is offline
Have you tried tweaking yours back into shape?
Noah
2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title
16' Ski-Doo XS Renegade X 1200 4T
16' Specialized Fatboy trail
02' ZRX 1200r R.I.P.
72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been)
15' TW200
Old 05-03-2018, 12:21 PM
I tried. The airbox doesn't sit right. Plastics are kinda buldging out. I'll have to strip it completely and figure out. Any pointers would be great.
Old 05-03-2018, 01:22 PM
nknudsen's Avatar
Depending on how's it bent up, I would strip it down completely so it's just the bare subframe bolted to the frame. Take measurements to different areas of the bike to reference from side to side & up and down. Use a long chunk of 2x4, square tube, pipe or whatever and carefully work it back it it's original position still mounted to the main frame. Get creative, maybe use a small bottle jack too if needed.
Noah
15' TW200
Old 05-03-2018, 05:47 PM
Leave the mounting bolts tight while doing it? I got Jack's, rubber mallets, a bunch of stuff. I just don't even know how to take the airbox out. Almost considered running a uni pod filter right off the carb with the dust protector.
Old 05-04-2018, 04:28 PM
jcs003 jcs003 is offline
sold and shipped.
Old 05-05-2018, 06:56 PM
I will let you know what I receive it. Thanks man.
Old 05-09-2018, 07:36 AM
Fitment was amazing. I used my original seat by drilling a hole in the rear. Seems like it might work. It clears everything. I'll find out when I get my plastics. I got a 2007 entire airbox assembly. I just stuck the filter on the carb so I could do some testing. Runs great. I want to get a headlight so I have to figure out the wiring. I found yellow is the power, but the green/ yellow and purple don't have power running to it. So I need to figure out where a high/ low switch would hook up and I'm sure things will change. That's my next hurdle. I got a light off my old it200 and I got the high low switch off it. It should work..... A+ seller. Everything was smooth and for only $75 bucks shipped, it was a great deal. Highly recommended seller.
Old 05-09-2018, 07:40 AM
It was severely bent when I took it off the bike last night. Not when worth saving unless you want to spend some time on it. It is lighter than the steel one I just got, but I can't see the steel one bending at all. Much better quality.
Adding electric start to 125 .. welsh.Z.S. Enduro Electrical & Wiring 1 05-07-2017 12:08 PM
Removing electric start Mark Grumke Enduro Engine - 2 stroke 3 02-19-2017 08:37 PM
Will there be an electric start for 2012 nmrider General Discussions & Announcements 5 09-19-2011 03:04 PM
New 2011 Gas Gas EC 300 (Electric Start) onegreyghost General Discussions & Announcements 32 08-31-2010 07:23 PM
electric start 2 Banger Gas Gas Klausen Enduro Engine - 2 stroke 1 06-21-2010 06:19 PM
