#51
A Suzuki sprocket that does fit is from a DR 250 or DR350 from 1990-1995. I know it fits because I have two for my 2001 xc300 I am not sure if GG hubs have changed since 2001. I'm looking forward to seeing how you work this out. <<<<<edit> oops, didn't notice how old this thread was HTH Dean
Thanks to FLY Racing. Last edited by motogroove; 06-20-2011 at 07:07 AM. Reason: need more coffee |
#52
Suzuki made two different DR models in two different sizes during those years: the regular DR and the "S" model. Only the rear sprocket from the "S" model will fit gassers. The sprockets you have must be for a DR250S or a DR350S.
#53
Motogroove,
Look back at my posting from October and it shows what Kawasaki wheels fit for sure and what I speculate will work from some quick research. I forgot to make the update from my test on the later Kawasaki rear wheels as I picked up a 2003 KX 250. That wheel will not fit without some major thought. The 2003 (and I expect newer) KX rear axle was a larger diameter than the one from my 1999 KX 250. While you may be able to find a bearing that will fit the hub and match the GG axle I was not able to verify sprocket and disc spacing. Good luck finding something else that fits and please post if you do find something! Eric
2018 GG 300 GP 2014 GG 300 Racing E 2002 ATK 605 Dual Sport 2003 KX/KDX 220 hybrid 2021 Kawasaki KRX 1000 Trail Edition 1974-86 Vintage Can Ams, SWMs, Puchs, etc. |
#54
Thanks to Coopernicus for the KX update. I posted that other thing before reading all the pages. dirtstars on ebay seems to be the best idea. An extra set of wheels would be nice for many reasons.
Thanks to FLY Racing. |
#55
DR250 L/M/N/P 90-93 DR250 L,M,N,P Off Road 90-93 DR250 S-L/M/N 90-92 DR250 SE-P,R Off Road 93-94 DR250 SE-P,R,S Off Road 93-95 DR250 SE-P/R/S 93-95 The DR250 models without the "S" use the JTR808 sprockets while the "S" models all use the JTR822 sprockets same as GasGas and late model Huskys. http://www.jtsprockets.com/52.0.html...el_uid=6851&p= |
#56
so the coclusion is?
kx250 pre2003? will fit, with no mods other than spacers? pre90 model cr250 rear? is this correct? not worried about sproket or rotor crossover, just hub/wheel... cheers |
#57
I went to the RAD website, and called them for some clarification.
Eco hub $280 ("Our strongest hub. It does not have the fancy drill outs and it weighs more, but it is probably our strongest hub.) Heavy duty spokes $70 DID wheel 18x2.15 $164 For a total (sans bearings and other stuff.) of $514. |
#58
Did the ktm fit on the gasgas
#59
No, KTM wheels do not fit Gasgas.
Anders "So you know, that you're over the hill when your mind makes a promise that your body can't fill" (Little Feat: Old Folks Boogie) 2015 EC200 Racing: TE bars, Rekluse Core Exp 3.0, 38mm Lectron & Ohlins S3 steering damper 2006 EC200: 2011 plastics, Rekluse Z-Start, revalved KYB forks & Scotts steering damper 1998 Bimota Supermono 1986 Duc Mille S2 1975 Guzzi sidecar hack 1961 Morini Corsaro 125 etc |
Thread Tools | |
Display Modes | |
plastic fitment | randy | General Discussions & Announcements | 11 | 02-03-2010 03:03 PM |
air filter fitment | wence | Enduro Engine - 2 stroke | 6 | 12-23-2008 09:49 PM |
Gaerne SG 10 Fitment Question | Boomhauer | Enduro Product Reviews | 5 | 12-16-2008 07:04 PM |
Aftermarket wheels. | Ud_luz | Enduro Chassis & Body | 3 | 12-08-2008 05:59 PM |
Gear box mess (circlip fitment) | craigyboy | Enduro Engine - 2 stroke | 2 | 10-28-2008 10:11 AM |
