CDI - Test? - Replacement?
Hi guys, if you check my "engine sputtering" post you will see that I've come down to the belief that my CDI is knackered.
Does anyone know how to test these CDIs? Does anyone know how to repair these CDIs? Does anyone know where a universal CDI can be bought? |
http://www.jdracingignition.com/index.html
Only ?479... I was hoping for something cheap that I can at least test the bike out with...
Try motocroscenter.com. They might be able to source it cheaper.
Carmo.nl tested an obscure (honda crm) cdi I was working on a while back. Looks like they do repairs and modifications too. Turnaround was reasonable, about 2 weeks posted uk > nl > uk and cost was about 70 GBP, I think.
Would I be right in thinking the cdi are the same for most european 2 strokes (ktm/tm/husky) around that age ?
'00 Montesa Cota 315R '13 Husaberg TE 300 |
As above, KTM use the same Kokusan ignition and CDI as gasgas', the CDIs use the same plug. The maps will be slightly different but it is probably easier to find a KTM one to borrow to try.
http://www.hpi.be/ also has complete ignition systems and sells separate CDI-boxes. Think i will buy from them if my CDI turns out to be bad..
Brake pad replacement. | Colemanian | Enduro Chassis & Body | 1 | 05-03-2013 12:10 PM |
Replacement Lever | skraMnoR | Enduro Chassis & Body | 9 | 04-30-2012 04:47 AM |
replacement footpegs | splint | Enduro Chassis & Body | 26 | 01-08-2009 12:42 PM |
Needle replacement tip | scarylarry | Enduro Intake/Carburetion - 2 stroke | 5 | 08-07-2008 02:01 PM |
Replacement Kickstarter | svt2224 | Enduro Engine - 2 stroke | 2 | 03-28-2008 02:39 PM |
