Old 08-30-2018, 07:50 AM
KsGman KsGman is offline
Default Replacement Oil Drain Plug
I am doing the first oil change on my new (to me) 11 300ec and the hex head drain plug was nearly rounded out. When removing that plug, no gasket came out with the plug. There is a copper gasket pressed up into the case that does not appear to want to come out (easily).
The replacement plug I purchased from Matto came with a steel washer/gasket.
Wondering if anyone else has purchased this plug; is the steel ring a throw-away (assuming the copper washer in the bottom of the case looks good)?
Thanks.
11 Gas Gas 300 EC
17 KTM 690 E
08 KTM 300 XCW
Old 08-30-2018, 10:53 AM
Neil E. Neil E. is offline
Compare the working surface of both drain plugs, if they match there is no harm in using the copper washer. Inspect the copper washer closely; they do crush a bit. Thickness is not critical but you need a smooth sealing surface.
Old 08-30-2018, 01:19 PM
Thanks Neil.
On our other bikes, the copper washer always sealed between the bottom of the case and the plug (ie-it comes off when removing the plug). It was different that this one is pressed up into the case, so I wasn't sure if the washer/gasket that came with the Matto replacement plug was supposed to be used in addition to the copper one.
Good idea though-I do need to check, if the diameter of the flange of the new plug seats properly on the existing copper washer, hard to see a need for the steel one provided.
11 Gas Gas 300 EC
17 KTM 690 E
08 KTM 300 XCW
Old 08-30-2018, 06:20 PM
pscook's Avatar
pscook pscook is offline
Here are a couple of threads where we discuss different options for sealing the oil drain plug. I still use the PTFE orings with no issue (not a gasser, but same dimension plug). As GMP says in one of the threads, the oring crushes down easier and provides a better seal than the copper or steel washers.
http://www.gasgasrider.org/forum/sho...highlight=ptfe
Phil
(New bike pending...)
drain plug jimjim "Wanted to Buy" & "Want To Trade" 6 05-09-2018 01:10 PM
drain plug ec 200 kiss161 Enduro Engine - 2 stroke 8 01-15-2017 07:51 PM
2T drain plug wence Enduro Engine - 2 stroke 0 10-13-2009 04:28 AM
oil drain plug nitroman Enduro Engine 4 stroke (including EFI & Exhaust) 1 08-18-2009 07:32 AM
Oil Drain Plug MIKEWA Enduro Engine - 2 stroke 4 01-27-2007 06:19 AM
