Old 07-21-2010, 10:43 AM
dank's Avatar
dank dank is offline
+1 on the phone call. i called him about some suspension stuff a while back, called three or four times, and he was always available and willing to talk. definitely worth your time, even if the call is expensive.
03 ec250
hyde skidplate, cycra handguads, protaper contours
"what? it seemed like a good idea at the time!"
Old 06-27-2018, 04:34 AM
Novice Novice is offline
Originally Posted by chucky View Post
I have read evrything regarding jetting on this forum , the problem is I live in South Africa and have limited access to the different needles described in this forum . The local Gas Gas agents recomend and use a needle that canbe purchased from KTM agents - N3EH , however I dont think this needle works well in the 200 , but I might be wrong that is why I am posting to get advice !!
I have also tried a N3CG needle which is a little better but still not perfect , I know that it is richer on the straight portion and half a clip richer on the taper . I think these needles are too lean on the 1/4 to 3/4 throttle range , also when I do a plug check it is black and wet ( this confuses me even further .
Hi Chucky (or anyone who can assist) sorry to rehash this old thread but I just got a 2007 Ec200 for the mrs, she idles ok-ish but the revs drop after 10 seconds and then she fails to idle at all, there is a constant bog in low (0 to quarter) throttle position. from there on she wakes up and sings quite nicely, all be it hellishly thirsty on juice (6ltrs per 50kms).
currently on:
N3EH #3
175 main 42 pilot
1.5 turns out on AS
slide #7
plug is black and wet (fouling plug every 3rd ride)
I`m keen to find out your best setting as I too reside in South Africa and the real life experience could help me sort out the bike as this is the first 2T (and only carb) bike in the family I`m a little out of my depths.
2007 GasGas EC200
2005 Honda CRF 230
2012 KTM 350 EXC-F
Old 06-27-2018, 04:49 AM
(F5)'s Avatar
(F5) (F5) is offline
For a start do the float level, search on this site. As1 carb if black screw cap carb top.
Then pull out the pilot jet and blow through it until you can see daylight. Smallest is easy to blog if left to sit with premix.
Plugs should last a year.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
what about this jetting? Gasgasogeros Enduro Intake/Carburetion - 2 stroke 3 12-11-2009 08:28 AM
Need help jetting an 06 EC 250 piperpilot12w Enduro Intake/Carburetion - 2 stroke 3 11-16-2008 11:19 PM
Harvest Classic 2007 European & Vintage Motorcycle Rally October 19 & 20, 2007 sanderjavant Republic of Texas 1 09-26-2007 05:18 PM
jetting help for 05 300 please... mackmack Enduro Intake/Carburetion - 2 stroke 5 09-03-2007 05:10 PM
06 300 jetting fury1 Enduro Intake/Carburetion - 2 stroke 1 07-31-2007 06:37 AM
