Old 03-11-2016, 04:51 AM
VilluEST VilluEST is offline
Default Which way do the linkage and swing arm seals go in?
Hi! I'm changing the swing arm and linkage bearings and I don't have o-rings there. It seems to me like someone has installed the seals on the link wrong way, because they are not the same way as for example the ones for wheels. The seal lip is against the needle bearing so there is no grease gap in between. So my question is, are they supposed to go that way or should I put new ones in the other way to have the gap for grease? The new ones have metal body exposed on the inside of the seal which can corrode easily so my guess is it would be better to install them the same way as wheel bearing seals.
Old 03-11-2016, 05:21 AM
RBrider's Avatar
RBrider RBrider is offline
Install them with the lip facing out. Your main goal is to keep water and grit out.
RB
Old 03-11-2016, 08:37 AM
I just called my local dealer and he told me the factory was installing them the lip side in, for some reason. He wasn't exactly sure why, but it might be because these seals have only one lip as opposed to wheel bearing seals having two. Despite the fact, he said it would be okay to give it a try and install them lip out and stuff the gap full of grease.
Old 03-11-2016, 11:32 AM
Elvis74 Elvis74 is offline
These seals are more like wiper ring, the lip must be on the outside
Send from iPhone using Tapatalk
4 strokes are only good for power generators
Old 03-17-2016, 04:13 PM
https://www.thebearingcompany.co.uk/...d_product=6539
Or buy double lipped seals...
2016 RM-Z450
Old 03-18-2016, 07:06 AM
stian stian is offline
Or swap it out to use O-rings that are better. 20x from Fleebay costs nothing.
07` EC300SM. 09` KTM 250EXC. 70`CB350
Old 03-18-2016, 09:19 AM
I have always thought that good seals are way better in keeping water and dirt off than O-rings, though, they will wear much sooner?
Here in Estonia we have wet riding conditions most of the time. I actually found my bike had O-rings on the swing arm, but not on the linkage, and the swing arm bearings were full of water and rust. So I'd rather change seals more often than have water in bearings.
Old 03-18-2016, 02:02 PM
Newer GG uses O-rings, and not lip-seals. Dont know with KTM/husaberg, but I am guessing it works better.
Swing arm Nut Danj56 Enduro Suspension 2 02-22-2016 10:35 AM
Swing Arm/Linkage Bolts & Nuts mcnut Parts 0 12-08-2014 07:02 PM
'12 Linkage and swing arm bearings seitz331 Enduro Suspension 4 11-29-2013 06:59 PM
Synery Seals SACHS 18mm shock seals Synergy-Seals Enduro Product Announcements 1 09-30-2011 03:33 PM
07 swing arm ? REVERUP Enduro Chassis & Body 12 04-29-2007 08:59 PM
