Old 08-24-2014, 12:33 AM
On the 2009-2011 models with the AS2 you can do the lot with the tank still on. Loosen the carb mounts, turn it towards, remove the slide, turn it away and access main and pilot through the drain nut.
On 2012+ Remove seat and tank first.
I still find that if you want to remove the entire carb for whatever reason that the easiest approach is to remove the pipe/silencer (either or both) and then flip the subframe up.
Old 08-24-2014, 06:50 AM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
Originally Posted by Neil E. View Post
Jim's method is fine if you need to change jets. If you only need to change the needle, completely remove the seat and tank. Then remove the top of the carb to get the slide out. Works for me.
I rotate the carb and remove the top for more clearance; then, I rotate it the other way to remove the jets.
I love the way I can change main jet without removing the float bowl; just having to remove the drain plug for access.
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Old 08-26-2014, 11:31 AM
blamir blamir is offline
NECJ#3 40Needle 175MJ
http://www.youtube.com/watch?v=UlpuZ9FJ8y0
Old 09-04-2014, 04:01 PM
Hello guys. You are famous here, in our local gasgas team We bought an 2013 EC250R and EC250R 2014.
First i removed the 2013 carb. It was so dirty so i cleaned it.
Needle N1EF #2
MJ 162
Iddle 38
Air Screw 1,5 out
I am going to set this bike carb as mine 2012 . Both have the same carb and engine ?
The main question is what do you offer for 2014? 2014 is brand new and has s3 head with black head. And also has vforce4 .
Thank for offers.
2013 ec250r Jakobi Enduro Intake/Carburetion - 2 stroke 2 04-17-2014 08:08 PM
2011 Gas Gas EC250R EricW835 Used Bikes 3 10-20-2013 10:58 AM
2012 300 e start issue schlitzy Enduro Electrical & Wiring 2 08-31-2013 03:07 PM
EC200R vs EC250R (2012 model) Jakobi General Discussions & Announcements 30 02-11-2013 03:41 PM
2012 300 issue bones150 Enduro Intake/Carburetion - 2 stroke 7 06-22-2012 12:29 AM
