Old 03-07-2010, 01:10 PM
Kurdt Kurdt is offline
Default 250 to 300 Conversion
I am looking for a list of part numbers to convert a 2008 250 to a 300. What all has to be changed in addition?
Old 03-10-2010, 03:17 AM
stabak's Avatar
stabak stabak is offline
anyone?
Old 03-10-2010, 06:16 AM
gasser's Avatar
gasser gasser is offline
Go to www.gasgasmotos.es then click on Selección Idioma in the upper right corner. That will give you a drop down menu where you can select English. Next put your pointer on motorcycles and select manuals from the menu that pops up.
Old 03-10-2010, 06:59 AM
jiauka jiauka is offline
You need:
cilinder,
piston,
rings,
Piston pin,
piston pin snap rings (2),
Piston bearing.
cylinder gasket,
head,
head Orings,
Head water hose gasket,
Reed Valve spacer.
Reed valve gaskets (2).
You also need to take the power valve from the 250 and place into the 300, I would recommend to replace PV bearings too.
have fun,
j.
Old 03-11-2010, 12:17 AM
stabak's Avatar
thanks people
Old 03-17-2010, 01:53 AM
dareuk dareuk is offline
did you do it?
Old 03-17-2010, 07:08 PM
2 strokes 4 life's Avatar
2 strokes 4 life 2 strokes 4 life is offline
Another option is Eric Gorr at Forward Motion in the USA. Makes a 275 big bore kit. Only $400 I think.
2002 Gasgas EC250 (gone not forgotten)
2012 Ktm 300xc
2001 Gasgas EC300
Lifes journey is not to arrive safely at the grave in a well preserved body, But rather to skid in sideways totally worn out shouting holy cow what a ride !!!!
Old 03-18-2010, 04:46 PM
cdn280 cdn280 is offline
Originally Posted by dareuk View Post
did you do it?
Don't know if he did it, but I did a 300 to 250 conversion. Easy as it could get. Piston pin, bearing, clips are the same. Only the inner cyl head O ring is different. I left the reed valve spacer in with the 250 setup. Anyone know why it should be removed ? It runs and idles excellent with a lot less surging and chain slap when just cruising.
Didn't even have to change jets (yet), just a tweak of the air screw and idle, and richened the LTR needle 1 clip. Funny it seems to be running leaner as a 250.... maybe the modded head it came with makes it flow more ??
Old 03-30-2010, 04:45 AM
stay_upright's Avatar
stay_upright stay_upright is offline
cdn - why did you change?
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
'95 ish XR630 (died many times in Oz)
Old 03-30-2010, 06:05 AM
Several reasons. But mostly:
- I found a very reasonably price 250 top end, so why not have a spare
- I had moved from a 280 trials bike to a 250 and my riding skills instantly improved. Probably with the extra traction gained with the softer power. Guess thats why the extreme enduro guys use a 250 more often than not. A bit more forgiving but the same power is there if you wind it up a bit more.
- this aging body was finding the instant mega off idle power of the 300 a bit tiring at times. Usually late in the day when trying to avoid the singletrack trees with the slightest crack of the throttle or multiple attempts trying to find traction on hills and in the real slow slick stuff.
ec 125 conversion? eddy field1 Enduro Chassis & Body 1 09-03-2009 09:00 PM
07 200 to 05 conversion brains Enduro Engine - 2 stroke 5 07-12-2009 12:54 AM
MY FSE 450 to SM conversion cal_tony Pictures & Videos 11 02-05-2009 10:11 AM
