Old 12-18-2010, 07:06 AM
iancp5's Avatar
iancp5 iancp5 is offline
Originally Posted by dank View Post
so is it still a keihin pwk model? they list the pwk35, and the pwk air striker.
It looks exactly the same as any other PWK except perhaps the very latest fitted to GasGas which I believe is slightly different. I tried looking at the PWK parts fiche but there isn't enough detail to see the difference I have. Next time I have it apart I'll try to remember to photograph it.
Old 12-18-2010, 08:29 AM
stainlesscycle's Avatar
you could purchase a 36 on ebay for around $50... if it has the right slide in it (#5 i believe) you could swap everything else in from your carb ...
the main thing i noticed when i switched to the 36 carb is the air screw had a much more drastic affect. when you get it close, you can definitely tell, the revs shoot right up.... mine is working perfectly, wouldn't switch back to the 38 if you paid me.. and i can ride a 2 hour race and use only 1.3-1.7 gallons...
07 ec300
www.stainlesscycle.com
Old 12-21-2010, 10:03 AM
iancp5's Avatar
Not many 36mm come up on eBay here (UK).
Do you know about OKO? They're PWK copies but they seem to be a lot cheaper. Wondered if any good? Have seen brand new ones for Sterling 110, what's that about $150
Old 12-21-2010, 02:26 PM
i have no experience with them.
if you do some research, you can find the carb - i believe (but i'm not 100% sure) 1990-1991 kx125 was 36mm pwk. some ktm 200's were 36mm. if you search ebay for 1991 kx125 or ktm 200 carb i'm sure you'l find one inexpensive.....
07 ec300
Old 12-23-2010, 05:08 AM
iancp5's Avatar
I can see a an 1994 RM125 carb being listed as a 36mm PWK - do we know if that's correct? I ask as from a breaker and I've had the numbskulls send me all sorts of rubbish in the past despite being specific....................................... Impatience got the better of me and I bought it.
Shame I can't get a decent idle on the 35mm because it runs pretty well in that otherwise. Just tricky because the jetting is so different from everyone else's experience.
Old 04-11-2011, 04:25 PM
iancp5's Avatar
Found an air leak! No wonder it was erratic.
Am now on 48, FEJ #4, 178 #7 slide
Feels like it needs to be richer at about 2/3 -> 3/4 throttle so may try bigger main although wide open is ok.
LTR or JD Jetting Kit Elvis74 Enduro Intake/Carburetion - 2 stroke 7 04-08-2010 02:49 PM
04 ec 300 Jetting lordfeyr Enduro Intake/Carburetion - 2 stroke 12 01-26-2010 03:16 AM
Need help jetting an 06 EC 250 piperpilot12w Enduro Intake/Carburetion - 2 stroke 3 11-16-2008 11:19 PM
jetting help for 05 300 please... mackmack Enduro Intake/Carburetion - 2 stroke 5 09-03-2007 05:10 PM
06 300 jetting fury1 Enduro Intake/Carburetion - 2 stroke 1 07-31-2007 06:37 AM
