Case hole?
School me. What is the tapped hole in the bottom of the cases for? The small hole forward of the drain plug as seen in this photo from the owners manual.
i think this is the same hole...this is a thread a few months ago..
http://www.gasgasrider.org/forum/sho...ght=case+drain
broken down over 60 slow rider.. |
If you're talking about the one without the plug it's a drain/vent for the flywheel/stator cavity. It is meant to be left open. The other one (with threaded plug) drains the crank case in case of a water drowning.
jeff '00 XC250 (mine) LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion. '04 EC250 (the kids) (he can do his own mods haha!) Last edited by jostby; 11-28-2010 at 06:23 PM. Reason: a little more info added |
you bet... i dont think i searched it either.... just saw it when it hit before..
Hole In Cylinder | PEB | Enduro Engine - 2 stroke | 1 | 09-07-2010 10:19 AM |
Ignition drain hole. | roostafish | Enduro Engine - 2 stroke | 3 | 11-28-2008 08:08 PM |
2008 Swing arm threaded hole ? | REVERUP | Enduro Other... | 7 | 11-21-2008 07:36 PM |
M6 hole under engine? | moff747 | Enduro Engine - 2 stroke | 2 | 03-19-2008 10:48 PM |
07 GG300EC - small hole at btm. of engine? | g dirt | Enduro Engine - 2 stroke | 4 | 02-26-2008 05:48 AM |
