Go Back   Rieju & GasGas Legacy Riders Club Forum > Classified Advertisements > Other Stuff...
Other Stuff... Vehicles, RVs, Trailers, gear, dogs that steal tools, etc.
Old 11-30-2013, 09:29 AM
john r b's Avatar
john r b john r b is offline
Default portable generator/inverter
I'm getting prepared for the winter power outages. I've been looking at the Honda eu6500is gen/inverter. Kinda pricy. Does anyone have experience w/ Northern tool and there generators? Iam thinking of serviceability etc. My local Honda shop is here in town. Nearest Northern tool is 140mi away. Thanks fella's
Old 11-30-2013, 03:50 PM
rgranger's Avatar
rgranger rgranger is offline
if you leave it stored for any time, drain the fuel!!!
It is very quite.
Rob Granger / Katy, TX EC300
Old 11-30-2013, 04:03 PM
john r b's Avatar
Thanks Rob, Every small motor i own gets the fuel run dry each storage peroid.Every thing(gas) around there has 10% ethanol.But no experience
w/ Northerntool generators?
Old 11-30-2013, 04:09 PM
bowhunter007's Avatar
I'm a huge fan of Honda small engines...so far, never had one break down. I personally spend the extra money for a Honda powered...generator, power washer, etc. Just my $.02 My equipment gets used year round, so draining fuel isn't necessary.
Old 11-30-2013, 06:03 PM
john r b's Avatar
Fyi they all have Honda motors, the ones i'm interested in.I guess it's about the generator it's self. I know Honda is great ,beaning a 6.5k inverter virsa a regular generator.And cost's
Old 11-30-2013, 11:39 PM
rgranger's Avatar
So, this is all what I have heard from friends that have had the HF/NT generators. The motors can be fixed, very, very, very, very, very difficult getting it repaired of the generator/inverter takes a dump. Many will have decent motors and electronics from china, parts were hard or impossible to find. Several just junked the HF/NT/XX unit and wound up buying honda or genirac (sp).
Old 11-30-2013, 11:43 PM
rgranger's Avatar
ps: I found out the hard way! Forgot and left the fuel on, it eventually ate the float needle and over 4 months it flooded the carb, cylinder, gear case, and exhaust. I replaced the needle, flushed everything and it was running fine so I ran it dry and it set for 4 weeks and now the carb is, not sure what the technical term is, "dicked" again? I have a bad arm right now, so it is now at the honda shop, pretty sure this is going to hurt.
Old 01-26-2014, 07:59 PM
Ud_luz's Avatar
Ud_luz Ud_luz is offline
I bought a little HF Kipor inverter generator about 8 years ago. It has hundreds of hours on it and the only thing I've replaced was the fuel pump. I bought an EU2000i at the same time and I've never even started it.
Best $300 I ever spent.
04 Montesa 315R, 07 EC300, 21 KTM Erzberg 300, 21 Sherco 300 SEF-F, 23 KTM 690, 23 Rieju Mr Pro 300
Old 01-26-2014, 09:57 PM
I have switched over to Avgas in my generator and other small engine products that are stored for more than a few months. Avgas has a long shelf life and has no added alcohol. Avgas is a leaded so do not use it in anything with a catalytic converter.
Gas to Propane generator conversion GMP Other Stuff... 5 11-11-2012 06:24 PM
flywheel weights kokusan generator Caravan Monster All Other Bikes... 5 06-14-2010 11:21 PM
Spring Generator moto9 Enduro Suspension 0 03-10-2009 01:51 AM
