Old 11-28-2010, 02:46 PM
Neil E. Neil E. is offline
Default Case hole?
School me. What is the tapped hole in the bottom of the cases for? The small hole forward of the drain plug as seen in this photo from the owners manual.
Old 11-28-2010, 03:43 PM
jhendr3702's Avatar
i think this is the same hole...this is a thread a few months ago..
http://www.gasgasrider.org/forum/sho...ght=case+drain
Old 11-28-2010, 06:19 PM
jostby jostby is offline
If you're talking about the one without the plug it's a drain/vent for the flywheel/stator cavity. It is meant to be left open. The other one (with threaded plug) drains the crank case in case of a water drowning.
'00 XC250 (mine)
'04 EC250 (the kids)
Old 11-29-2010, 09:53 AM
Thanks, I couldn't find it using the search function.
Old 11-29-2010, 10:16 AM
jhendr3702's Avatar
you bet... i dont think i searched it either.... just saw it when it hit before..
Hole In Cylinder PEB Enduro Engine - 2 stroke 1 09-07-2010 10:19 AM
Ignition drain hole. roostafish Enduro Engine - 2 stroke 3 11-28-2008 08:08 PM
2008 Swing arm threaded hole ? REVERUP Enduro Other... 7 11-21-2008 07:36 PM
M6 hole under engine? moff747 Enduro Engine - 2 stroke 2 03-19-2008 10:48 PM
07 GG300EC - small hole at btm. of engine? g dirt Enduro Engine - 2 stroke 4 02-26-2008 05:48 AM
