Go Back   Rieju & GasGas Legacy Riders Club Forum > Community Forums > Australia & New Zealand
Old 07-04-2021, 04:01 AM
HurricaneHarry HurricaneHarry is offline
Default Plug Fouling
New member here, in Newcastle NSW, 08 EC300.
Anyone got any suggestions re jetting, curing plug fouling? I haven't ridden it yet but bought from a mate who tells me it does this sometimes. It has new top end and the old piston had a lot of carbon on the crown.
Old 07-04-2021, 03:44 PM
"does this sometimes" sounds like one of the circuits is rich. i had a kx250 that would foul a plug after long v. slow downhills, where it was just idling so leaned up the pilot jet and problem sorted.
you will need to try and find out which circuit is off - start by checking the jetting database for similar bike and conditions
Old 07-05-2021, 03:06 AM
(F5) (F5) is online now
Check the carb needle jet. Take carb apart and look down the hole with the slide removed, a good light and a magnifying glass. It should be round and not the least bit oval.
Check gearbox oil level.
I've never fouled a plug.
Old 07-05-2021, 05:30 AM
Default Carbon
I noticed the piston recently replaced had a lot of carbon build up on the crown. I was also told it doesn't usually idle well. Other threads I've read have given me the impression that unsuitable jetting is a common issue. I would've thought this would be an easy fix - ie these are the carb settings to use. I think I'll just ride it a bit and see how it goes. 50:1 Motul semi-synth?
Old 07-05-2021, 03:38 PM
I agree.
how old is the bike? and what type of riding do you do? I was mostly slow technical stuff, not wfo for any extended periods. Found motul 710 worked best as it had a lower flash point, but oil/fuel mix is not the fix
Old 07-05-2021, 10:32 PM
What carby is fitted to it? Round top As1 or bolt on As2?
Read the jetting threads. If it has the stock jetting pick anything posted on there and it will be better!
Old 07-08-2021, 06:45 AM
Originally Posted by swazi_matt View Post
I agree.
Same as you. It's an 08. Fresh piston.
Old 07-08-2021, 10:40 AM
Bryan's Avatar
Bryan Bryan is offline
on my old '01, the carb had an internal issue. I never could trace it down, but a friend who I sold the bike to did. When the carb was assembled at the factory, it was not seated properly, and fuel was leaking by internally (as he described it to me).
This is my way of saying it may be more than a jetting issue. If you can test it against a know good carb if you can borrow one. That is how he figured out the problem was in the carb and not jetting.
07 EC 300
06 Gold Wing
(2) 06 CRF 150 F
Old 07-08-2021, 08:37 PM
so 12-13years old, F5's solution could apply especially on an old bike
Old 07-13-2021, 10:46 PM
ditezz ditezz is offline
I had the same issue on my 08. Could not get to idle consistently, Jetting was a pita , could never get it perfect until I replaced Jet Block O ring.It was leaking and causing all the dramas.You can pick up one on eBay cheap.Youtube is your friend for installation.Not that hard if you watch someone do it .Good luck
Spark plug fouling Louis069 Enduro Intake/Carburetion - 2 stroke 35 10-20-2021 02:18 PM
Fouling plugs cladoo Enduro Intake/Carburetion - 2 stroke 21 05-11-2019 08:45 AM
Fouling plugs? TavisB Enduro Intake/Carburetion - 2 stroke 9 09-12-2012 09:56 AM
plug fouling problem unsolved fabulous furry Enduro Engine - 2 stroke 29 06-20-2012 10:09 AM
Plug fouling wheels244 Enduro Engine - 2 stroke 13 05-13-2007 03:48 PM
