Old 08-28-2020, 07:14 PM
Pauloz Pauloz is offline
Default keihin PWK information wanted
Hi
Could someone point me at a diagrammatic and manual/tuning guide for my carby from a 2011 ec300 - its the Keihin PWK 36mm. (FK0261 WAV)
I have looked and if it is under my nose I cant see it.
Thanks in advance.
Old 08-29-2020, 11:14 AM
The 2011 owners manual (https://gasgas.com/en/manuals) only contains a correction table for various temperatures but no jetting chart.
The factory setting is a good point to start with. Change jetting according to temperature and altitude. You may find good jetting data here:
http://www.gasgasrider.org/forum/showthread.php?t=2162
Old 08-30-2020, 07:48 PM
The stock needle N1FE needs to be modified. First choosing some sturdy linesman pliers, cut into 2 or more equal lengths.
Problem 1/2 solved.
NEDJ needle from an RM250 is my vote.
Old 08-31-2020, 04:00 AM
rodent's Avatar
rodent rodent is offline
The stock needle N1EF needs to be modified. First choosing some sturdy linesman pliers, cut into 2 or more equal lengths.
Problem 1/2 solved.
NECH here, when I can finally get out I'll sort out which needle notch
Old 09-01-2020, 07:43 PM
Thanks for reply guys.
As it turns out there is JD kit in this carb.
I will stand down now.
Old 09-02-2020, 07:44 AM
Just as a side note, I went from JD to NECW and the bike run well but very aggressive. I then took the NECH, which is one full clip richer than the NECW and the bike runs a lot better now
The Tire Thread - Please add your information noobi Enduro Chassis & Body 37 07-26-2021 12:17 AM
Information for clutch please Cox76y Enduro Engine 4 stroke (including EFI & Exhaust) 0 12-05-2017 10:05 PM
Information please NewB GasGas Member Polls 3 10-25-2007 09:36 PM
FAQ Information Needed.... webmaster General Discussions & Announcements 0 08-02-2006 11:28 AM
