Enduro Engine 4 stroke (including EFI & Exhaust) 4 stroke engine, EFI, and exhaust discussion |
#11
The bike then obviously will draw unfiltered air so that can not be good. This will also show a leak for any drop of oil that is drawn through the breathere. I will therefore start by pluging that hole and see if that fixes things. My guess it that the former owner made that hole because oil was flowing out through the airl filter and he thought this was a fix for that!!!!! |
#12
ouch, bad fix.
#13
I'm familiar with the early GasGas 4-strokes.
This problem came up several times, especially in the 2005 FSE450. Every time it happened and I was contacted, it was with nearly new or new bikes. Then, the cause of the problem was blowby from the rings not being seated properly. The owner had started off using a top grade synthetic oil and the extra lubrication properties of the oil had not allowed the rings to seat properly. The resulting blowby would not only blow oil smoke out the breather, but was actually depositing oil in the airbox. With the new bikes, we were able to fix the problem by going to a non-synthetic (but good grade) oil long enough to get the rings to seat properly. It would stop the blowby, and the "oil in the airbox" problem. Then, the owner could go back to their preferred lubricant. Taking this line of thinking further in a logical manner, and taking in consideration the probable amount of use your bike has had since it was new, I think that you are most likely ready for a top end job, or at least a new set of piston rings to stop the blowby. Have you done a compression test to check how well the rings are sealing? This just may be your problem. Good Luck with your bike. The 2005 was my favorite year for the early GG 2-strokes. The slipper clutch was nice, and the harder you pushed the bike in the tight trail, the better it responded. Except for the weight, if felt quite a bit like the GG 2-strokes. Good Riding and Good Wrenching! Jim .
Jim Cook Smackover Racing Team LAGNAF '11 Gas Gas EC250 (primary ride) '06 Gas Gas DE300 2004 Gas Gas TXT300 Pro '94 Husaberg FE350 '86 Yamaha IT200 '86 Honda TRL200 Reflex '04 KTM 525EXC (soon to be dual sported) Several others, including project bikes, Deb's bike, and a fleet of grandkids' bikes Let's go riding! http://www.jebruns.com/Wudi19/wudi19.html http://www.ahrma.org/schedules-results/cross-country/ |
#14
hi Jim
thank you for your comments. No I have not done a compression test. The bike has only done 4.100 km, guess its too late to try the non sync oil treatment? One thing you mention is oil smoke out of the breather. I have however not observed any oil smoke from the breather or exhaust at startup or under acceleration. Hopefully that gives hope regarding that there is no blow-by by the rings. regards Ragnar |
#15
The "breather" I was speaking of was a transmission/crankcase vent hose that was run to the air box.
I'm sorry for the confusion. I'll try to do better. .
Tags |
airbox, leak, oil |
Thread Tools | |
Display Modes | |
Airbox leaking ...?? 07 FSR need help | Why Z? | Enduro Chassis & Body | 4 | 06-11-2014 09:15 PM |
forks leaking oil | Barton | Enduro Suspension | 4 | 01-19-2014 04:29 AM |
Leaking Oil not sure where from, see video ? | wakeymatt | Enduro Engine 4 stroke (including EFI & Exhaust) | 8 | 04-16-2013 05:34 PM |
leaking gascap | BryanMcc | Enduro Chassis & Body | 0 | 03-24-2013 09:19 PM |
Leaking gas cap. | Mick | Enduro Chassis & Body | 24 | 04-03-2012 01:22 PM |
