Old 12-05-2018, 06:10 PM
BLD's Avatar
BLD BLD is offline
Default Remove Reeds To Install Lectron Carb?
Hello,
I am looking into switching to a Lectron for my 3013 XC300. I have done a bunch of reading and I know they are a few mm longer than my stock carb. Has anyone had to remove their their reeds on a GasGas 300 in order to fit like Lectron?s site suggests? It seems like they addressed the throttle cable issue I have read about here, and I like that I can keep my handlebar-mounted choke lever.
Thanks
Edit: I am done caring why my apostrophes always turn to question marks!!!...
Old 12-05-2018, 08:14 PM
SS109 SS109 is offline
Don't need to on my '11 and it is more packed together tighter than the '12+ bigger framed bikes.
Old 12-05-2018, 09:31 PM
BLD's Avatar
BLD BLD is offline
Good to hear. How do you like your Lectron? Did you have to trim the rubber boots at all?
Old 12-06-2018, 01:25 AM
Anders Anders is offline
You must NOT remove your reeds!
Perhaps they are talking of the reed spacer block installed on some (all?) 300s.
I have a Lectron on my 2015 EC200. I bought it for the 06 EC200 and carried it over when I upgraded to a newer bike.
The installation is as easy as it gets, as long as you have a proper throttle cable. I use the long version of the Motion Pro KTM cable.
I do not use the cable choke on the Lectron, cable chokes are known to give some trouble over time. The choke knob is a litte hard to reach, but no real problem.
Old 12-06-2018, 01:34 PM
BLD's Avatar
BLD BLD is offline
Thanks for the reply! I have not removed my carb or reeds since I bought the bike used a year ago, not sure if I have a removable spacer. The dealer I found it at actually did a great job jeting the bike for my average temp and alt. The problem is when the guys call me with no notice to go ride in different places. I have no other jets, so I just adjust the clip for temp and then air/fuel...
I had not heard about the lever choke causing problems, good to know. If the bike is always fueled right I guess it wont matter. I use mine on cold days sometimes to help the bike settle back to idle (gets lean at lower revs, main has always felt a little richer).
Just bought a lectron carb Kendog Enduro Intake/Carburetion - 2 stroke 6 02-16-2016 04:16 AM
Lectron carb davedunaway General Discussions & Announcements 3 12-22-2015 02:52 AM
Can I remove my EFI and install a Carb? safetythird Enduro Engine 4 stroke (including EFI & Exhaust) 9 10-08-2015 05:14 AM
Lectron Carb singletracker Enduro Product Reviews 145 07-27-2013 12:20 AM
How to easily remove and install that pesky Keihin mlyle11 Enduro Intake/Carburetion - 2 stroke 6 01-04-2012 11:34 AM
