Old 07-11-2014, 07:10 PM
Cory C Cory C is offline
Thanks for the help, Much appreciated
Old 07-28-2014, 03:54 PM
barossi73's Avatar
so am going to try the nedh in place of my nozh clip3 40p 175m,bike is 2013 ec200r,whats a good start point with jetting for this needle based on what im running now.current setting pretty good but could be a little cleaner and seems these Suzuki needles suit th gasser.hav a 178,42,45 on hand.just want to be sure I don't swap out needle then lose ridetime waitin on jets I could hav had ready to go.also which clip setting to start with for nedh?bike is stock with unmod head and 1 base gasket,vforce3,pwk as2.premium95 @40:1.would be nice to get it close first time.thanks and sorry if ive missed this info somewhere else,200 specific data a little harder to find than 250,300
Old 07-28-2014, 06:30 PM
Same pilot and main you have now - H diameter on both means same pilot should work. Both needles supply similar fuel at WOT in their final taper so main should be good. Start in clip 3. Consider clip 2 if it feels a bit fluffy.
Old 07-29-2014, 02:06 AM
barossi73's Avatar
thanks again jakobi,dont mind tinkering but id rather be riding so its good to know it should be simple in advance.was pretty happy with th nozh but keen to find out what th fuss is all about.will post my findings when I get part and give it a spin.
Old 09-06-2014, 09:50 AM
barossi73's Avatar
4 weeks but finally got my NEDH needle!took bike for a good ride to get a benchmark b4 changing(and ripped the stock plastic skidplate in half on a root infested step).Thorough clean,then NOZH clip3out-NEDH clip3 in.re rode the same route after some initial tweaking of the screws.definite improvement in rideability-smoother transition onto pipe.more progressive rather than burble,WHAM!the hit doesn't 'feel' quite as punchy to me tho, but prob an illusion-because its ramps up smoother it hits less abruptly.the airscrew seems a little less sensitive? airscrew at 1.5 for now(1/8 turn richer than NOZH).Ride it some more,maybe a clip change...and order a better bashplate!
Old 09-10-2014, 09:30 AM
barossi73's Avatar
not convinced I don't prefer th nozh on th 200 at this stage.tried the nedh in #4 today.figured go 1 richer to be sure I needed to go leaner if that makes sense.definitely worse burble as expected.fingers crossed for clip#2next.airscrew still vague in its effect.pulled plug after running clip#3 and it looked perfect but it had quite a few hrs of nozh running prior to th couple on th nedh.will try #2 then throw nozh back in and try #2/3 again.
2013 ec200r
Old 09-10-2014, 11:35 AM
hamilton's Avatar
hamilton hamilton is offline
The nozh clip 2 works well in my 200, but I couldn't get the off idle power right without changing to a 6.5 slide.
15 GASGAS EC 250
19 Sherco SE 125R
Old 09-11-2014, 08:09 PM
barossi73's Avatar
thanks,that makes some sense as th 2013 manual lists a 7 with n1ef?.mine came stock with nozh and a 6(from memory,must check).6.5 could be the sweet spot...
2013 ec200r
Old 09-11-2014, 09:08 PM
hamilton's Avatar
Yeah, the 7 with n1ef is what came in my 250. 6 nozh was what came in the 200. The 6.5 was the magic part. Just ordered one for the 250, which has been ticking me off. 6 is too rich 7 too lean. good luck.
15 GASGAS EC 250
19 Sherco SE 125R
Old 09-14-2014, 06:08 PM
barossi73's Avatar
Missed the hit of the nozh so threw that back in clip#2 pilot 40,main175,as 1 3/4out.best setting ive found for mine so far.think the ned? is more applicable to the 250,300 maybe,where u might want to smooth the hit.on the 200 this setting gives a pretty smooth ramp onto a strong mid hit and good top.good idle,has 1 spot just as it gets on the pipe where it doesnt like constant throttle but it doesnt show when u accelerate through so isnt much of an issue.idle perfect at 1 1/2 if set at v low idle.at fast idle 1 3/4(which also seemed to ride better)
2013 ec200r
2010 EC300 Factory Jetting Specs - WTF? JP4 Enduro Intake/Carburetion - 2 stroke 197 07-04-2011 11:03 AM
torque specs kstreet Enduro Engine - 2 stroke 1 01-28-2011 07:05 PM
05 De 300 Specs VORMAN Enduro Electrical & Wiring 9 11-14-2010 06:36 PM
ring gap specs jostby Enduro Engine - 2 stroke 9 10-27-2008 06:18 PM
Torque Specs steve Enduro Engine - 2 stroke 8 02-26-2008 09:30 PM
