Old 12-11-2015, 04:32 AM
Default 2013 EC250R - 130hrs
Last couple rides I noticed the poor little bike getting softer off the bottom and through the mid. The kick starter felt to be rolling through a bit too easy, and often would take a 2nd or 3rd kick to fire up. Todays ride she was flaming out a bit when pulling up as well.
Compression gauge showed 15% loss from last piston.
Pulled down after the ride. Piston wash looked slightly rich in comparison to some of my others (which had been abused with lean jetting runs). Surprisingly not a whole lot of blow by noted, however quite a bit of polishing and wear on the skirts (both rear and front). Top ring gap measured .8mm. Lower ring .65mm.
All done in 65hrs ride time. Not sure what people are doing to get 300hrs out of their slugs.
Old 12-11-2015, 02:50 PM
barossi73's Avatar
hear no evil,see no evil,cross fingers there wont be any evil!
its hard to feel compression through the e start button!(i dont have one,cant say i miss it,esp as everyone seems to have trouble with it!)
Do you rebuild at "x" hrs religiously or as jug wears reduce the interval between topends?
Ive done 1 top end at 60odd on the 200 and everything was very good,wished id run it out to 80 at least.(belray h1r til topend,great protection,but excess spooge unless wot,now on castrol tts,a little spooge,will be interesting to see the entrails next rebuild)
But with accumulated wear i was thinking it might be a good idea to shorten the interval a little each time?Esp on the smaller cc.What are others doing?
2013 ec200r
Old 12-11-2015, 03:48 PM
Shorter interval on ring replacement may help to get more life out of the piston. As one of my buddies says... 'piston is just a ring holder'. Some will say that you may as well swap pistons while the jug is off, but if it is looking good maybe just do the rings?
Old 12-11-2015, 04:50 PM
I had considered doing just the rings, but realistically most of the effort lies in cleaning the bike up enough to get to the piston. Pulling parts off is easy! Making sure there is no dirt around to go where it shouldn't takes a bit more time and effort.
I figure for the effort its easier to just do the whole slug. Many times you do start to see wear on the skirts, as well as the ring end opening up. The rings do wear the ringlands to a certain extent, and the wear on the skirts allows the piston to rock in the barrel more than it would otherwise which likely increases were on the nikasil. For all those reasons I simply replace the piston - it's not that much money for the time and effort you spend doing the job (inc cost of gaskets, cleaning products, etc).
I have found the stock vertex pistons start to get noisy around 70hrs. Happened on both my bikes. On the newer one, I did the first piston at 65hrs and everything looked pretty good wear wise. I have some pictures somewhere and could check my notes on wear tolerances, but do recall thinking they weren't too bad.. but I could hear the piston rattle a bit on decel.
I was going to stretch this interval out but the bike was really feeling quite down on power. Very notable drop in bottom and mid. The comp reading confirmed my thoughts. The wear pattern and ring end tells the story.
On my other engine I put 110hrs on a slug and rings, and the ring end gap was bigger, but I don't recall the power dropping off like it has this time.
It may also be a case that I am riding the bike in more challenging terrain, at larger throttle inputs and simply wearing things out in shorter time frames.
Old 12-11-2015, 05:04 PM
Neil E. Neil E. is offline
I'm at 140 hrs on my current piston (don't know what brand it is). There is a bit of piston slap and it feels like the power is down some, however the compression tester still reads 200 PSI the same as it did when the piston was new. I'll run it for another season and see how it goes.
2011 EC250E
Old 12-11-2015, 06:31 PM
barossi73's Avatar
im really not that inclined to only do rings either,as you've done all the cleaning and dismantling anyway as above.its a bit like doing an oil change and not the filter i think(4t).i figure if you keep the slop to a minimum the jug must last longer,stay truer,and prolong its life(along with always having a fresh engine).then again if you can get 300 hrs on 1 slug you've saved enough $ to buy a new barrel!
new rings on a high hour piston are surely not going to seal as efficiently,and will probably wear faster and potentially give trouble IMO(far from expert,but plenty exp from chainsaws to tractors)
A new surface mated to a worn/pitted/polished surface never works as well and always wears faster(think new pads on worn discs,rapid wear)
anyone put a new diff head in a worn diff-usually makes them whine more!
would you replace a tapered wheel bearing inner race and leave the worn shell?
the exception would be the guys that are dead serious and do rings every 25 and pistons at 50 when the piston at 25hrs has very minimal wear
Jakobi you mention the stock vertex getting noisy around 70,i think you mentioned in another post that youve also used wossner,how did they compare?
BTW Im more than happy for you to keep abusing pistons with lean runs if it helps others with jetting/rebuild issues including myself!Your knowledge is a goldmine(high praise for an aussie,coming from a kiwi,keep up the good work!)
2013 ec200r
Old 12-11-2015, 07:11 PM
I've been able to pick up the 64mm Wossners for good prices (cheaper than Vertex). They don't make the same sounds, but that's not to say they aren't rattling around after some wear. It may be a case the cast ones resonate more.
No real difference in performance. In theory the Vertex is a bit lighter and should rev a bit more freely.
Old 12-11-2015, 08:34 PM
barossi73's Avatar
Interesting,i initially thought the bike felt/sounded slightly different after installing wossner but it was so negligible i wasnt sure if it was my imagination,i used a wossner on 1st topend but still have 20hrs or so til rebuild so will compare then.the recessed area in the piston(balancing,weight reduction,voodoo port?i havent a clue!)is a different shape than the vertex but i have no idea if it makes any difference as its below the rings?only theory i can think of is it may have a subtle effect on drawing crankcase mix into the skirt area?or the volume of the mix in the skirt area?
It doesnt particularly matter as both work well,but am curious.
Most probably its far simpler...they need a point of difference!
2013 ec200r
Old 12-12-2015, 12:23 AM
Interested to hear your thoughts once you pull the Wossner out.
Old 12-12-2015, 03:23 AM
rubber Jonny rubber Jonny is offline
I have no idea how people get so long from their piston \ rings. Mine was shot 1.4mm gap at about 90 hours. My mate who I ride with runs the same oil as me got 252 out of his and under 1mm gap.
Another KYB SSS Thread - 2013 EC250R Jakobi Enduro Suspension 135 03-29-2020 02:50 PM
2013 ec250r Jakobi Enduro Product Reviews 163 02-21-2016 03:52 AM
2013 EC250R - 65Hr Report/Review Jakobi Enduro Product Reviews 111 03-07-2015 07:33 PM
2013 ec250r Jakobi Enduro Intake/Carburetion - 2 stroke 2 04-17-2014 08:08 PM
