Old 05-08-2015, 12:51 AM
adv rider's Avatar
adv rider adv rider is offline
Default Turning radius
I have an issue that has bothered me since I bought my bike. It doesn't have a good turn radius, Riding single track w/ switchbacks is difficult. I have to take the far outside edge, and barely make it without going off the trail.
How much are you guys dropping the forks in the clamps? or what is your sag setting? I dealt with it, but after riding a new 300 xc-w- which turns amazing! I need to get it to turn like the pumpkin.
Admittedly , the gasser is more stabil at speed. But I mainly ride single track. The 11' 250 I had turned well, whats up with these? The forks hit the radiators, so I am not sure what else to do. Any advice appreciated.
12' xc300
2012 xc300 - Great bike! sold looking for 18+
Old 05-08-2015, 06:36 AM
hamilton's Avatar
hamilton hamilton is offline
I feel your pain, you will never match the turn radius of the ktm.
I modified the steering stop bolts until the forks all but touch the frame.
The forks should clear the radiators unless your guards are in the way.
15 GASGAS EC 250
19 Sherco SE 125R
Old 05-08-2015, 11:19 AM
VxZeroKnots's Avatar
VxZeroKnots VxZeroKnots is offline
I learned pivot turns.
Old 05-08-2015, 04:51 PM
adv rider's Avatar
Default Turning
The forks should clear the radiators unless your guards are in the way.[/QUOTE]
I removed the washers on the stops, forks now hit guards. I am hoping I can pull them back a bit somehow. And maybe lower the forks another couple mm.
Old 05-08-2015, 04:53 PM
adv rider's Avatar
Default turning
That would be good if I wasn't 5'5" and my feet are 6" from the ground.
Old 05-09-2015, 01:50 AM
No excuse, I've seen this guy called graham do them with his feet on the pegs ;-)
Old 05-09-2015, 03:47 AM
I'm short and ride tight singles all the time. Depending on the particular fork, I've dropped them through the triples with as much as 9mm above the top clamp.
At the moment I'm running some KYBs with reduced offset. I don't think it particularly helps as they also feel a bit heavier (take more effort to instigate a turn).
Apart from lowering the front, you could try raising the rear. 2012+ chasis responds well to approx. 98mm sag.
I simply set up for the corners. Use brakes or power or both to position the bike where you want. Rear brake sets the back end nicely. A good handful of front brake can make it dive a little to tighten up. Lean it over and slip the clutch and she'll scoot across. To be honest, I probably encounter more issues with the bar ends contacting tight trees (being wide across) than I do due to the bike not turning where I need it to.
Old 05-09-2015, 07:24 PM
adv rider's Avatar
Default Turning
[QUOTE=Jakobi;152361]I'm short and ride tight singles all the time. Depending on the particular fork, I've dropped them through the triples with as much as 9mm above the top clamp.
I ride tight singles mainly, the only time I think about the turning is on 180d turns. I am going to tighten up the sag, and see how it feels. The bike is fine everywhere else, but I would really like it to turn tighter also.
Old 05-10-2015, 02:09 AM
You may find pulling a link from the chain and moving the axle forward in the blocks helps as well.
Old 05-13-2015, 08:12 PM
adv rider's Avatar
Default turning
I also noticed that my chain/sprockets were needing replacement, and that the wheel was adjusted way back. So I now have new chain/sprockets,and will set it up forward in the swingarm. Wont be riding until next week, to find out how it turns.
Turning circle, how to improve? Fakesy Enduro Chassis & Body 19 05-21-2014 05:02 PM
'06 300 Speedo problems. Should turning of front wheel switch unit on? Jaluka Enduro Electrical & Wiring 4 09-25-2011 01:04 AM
Broken Radius noobi Injury & Recovery 23 08-28-2010 02:11 PM
spring affects on turning..... dank Enduro Suspension 17 08-20-2010 07:07 PM
