Old 03-27-2007, 12:15 PM
spm m//5 spm m//5 is offline
Default Help with 05 fse 450
I am wondering if someone could help me with locating the yellow and blue wires under the gas tank to switch the mapping. I have a blue wire with a yellow stripe and a yellow wire with a blue stripe are thoes the wires that I have to disconnect? Or where should I look. Thanks for your help.
Old 03-27-2007, 02:07 PM
bergerhag's Avatar
Under the rear of the tank is the EFI module. It is attached to the tank. Two wires are attached with a screw to the EFI casing (on the corner). One is a ground connection for the efi casing(think its black). The other should be your yellow/blue wire. There should be a rubber insulated connector that you can just pull apart.
Old 03-28-2007, 03:44 PM
Nick's Avatar
Nick Nick is offline
Make sure you leave the black wire connected.
Old 05-31-2007, 06:48 PM
Rappa's Avatar
Rappa Rappa is offline
Do you know if there is a yellow/blue wire on my '02 fse400/450? I looked and cannot find it. Looking for more power as it dies out at top end. Actually, it sounds like it hits the limiter too quickly. Hope it has something to do with this Y/B wire. Thanks in advance - Rob.
Old 07-06-2007, 10:20 PM
flybars flybars is offline
The yellow/blue wire disconnect only started with the '05 fse's. U do not have this lean wire connection.
'14 Beta 300rr
'05 GG DE300
'03 GG EC250
'01 XR440
'09 FZ1
Old 11-12-2007, 09:02 PM
sanderjavant's Avatar
sanderjavant sanderjavant is offline
I checked under my tank. The blue/yellow is unplugged but so is a black wire.
What’s the result if that’s the black wire that should remain connected?
Will it run too rich?
Old 08-01-2008, 12:46 AM
adpartain adpartain is offline
Default My 04 FSE
I have a 04 FSE supermoto
The question is, What are these wires all about? Changing mapping just by unplugging or plugging in wires?
My bike has started to pop a bit during decel and after a hard rev it pops at the height of the rpm's. This makes me think its running lean for some reason and maybe what you guys are talking about is something that will help me figure that out.
Someone enlighten me. What is this wiring thing you guys are talking about? I am interested. Hopefully somebody will explain this to me in detail. The more about my bike I know, The better.
Thanks
