Old 07-23-2011, 03:23 PM
06EC300 06EC300 is offline
Default Trail tech vapour Tach hookup
I am trying to hook up the tach wire on my vapor gauge....I attached the yellow wire under my seat to the red wire to the gauge and then grounded the black wire to the chassis.
When i fire the bike up the gauge seems to work fine at idle but when I rev the bike the gauge goes backwards.
I also tried the yellow wire that runs up to where the headlight is same thing happens
Any ideas on how to fix that?
bike is 06 EC300
2006 Gas Gas EC300 2T
Old 07-23-2011, 04:16 PM
Neil E. Neil E. is offline
I don't know about the Vapor unit, but on my Voyager tach input, I connected it at the ignition coil primary. This is the spade terminal on the coil itself. Trailtech's instructions said to wrap the wire around the high tension lead, but I wanted something a bit more solid for a connection. I verified this method with them before trying it. I did have to set the display to "tach/2" to get the correct RPM reading.
It sounds like you are referring to the power wires in your posting. Do you not have a separate wire just for the tach input? Check trailtech's web site for the instruction page (download section).
Old 07-23-2011, 04:34 PM
So you connected the red voyager wire to the spade connector with the yellow wire right at the coil?
Old 07-24-2011, 12:31 AM
rgranger's Avatar
rgranger rgranger is offline
I recently hooked up the vapor that I bought a few years ago for my husky. I would have to dig into it to look. I hope to get a ride in tomorrow, after I get back and clean it up I will take a look.
Rob Granger / Katy, TX EC300
Old 07-24-2011, 02:34 PM
I got it to work by wrapping the red wire around the plug wire.
now to figure out what the correct idle rpm is to make sure it's accurate.
Old 07-25-2011, 02:08 AM
if you have not already received a pm then pm me your email and i will email you the step by step pdf of how to hook up the tach. I am embarased to say i cannot remember who i got it from on this forum
Old 07-25-2011, 01:56 PM
I've got it all sorted out now
08' trail tech speedo help please. nick790 Enduro Electrical & Wiring 5 09-06-2015 11:51 AM
Trail Tech - Voyager HydroDog General Discussions & Announcements 13 11-08-2010 01:29 PM
Trail tech troubles skid jackson General Discussions & Announcements 8 06-02-2010 07:15 PM
Trail Tech X bars sammyj18 Enduro Chassis & Body 11 05-06-2010 09:39 AM
Trail tech endurance FULLBURNER Enduro Electrical & Wiring 0 05-01-2009 06:48 AM
