Old 06-02-2012, 03:27 PM
pscook's Avatar
pscook pscook is offline
Default 2002 XC300 Baseline settings
I am getting ready to dial in my suspension. I am using advice from this page and want to know where to start with "nominal" clicker settings.
43mm WP forks, allegedly valved by ESP. LTR replaced the fluid and seals a couple of rides ago, but said that the right base valve was so seized that he didn't want to remove it and damage the forks. Ohlins shock rebuilt/serviced by my road race suspension technician. Shims were broken so Barry simply replaced one-for-one on the shims. Don't know what the stack is, maybe I should drop him a note.
Anyway, I want to know a good "baseline setting" to start twiddling knobs and such. Any suggestions? I will say that I know absolutely nothing about off road suspension, having spent my last ten years working on road race stuff. I have a friend that can tell between single clicks of rebound on his WR400, but I am lost before I even start. In summary, keep it simple. I like simple.
Phil
(New bike pending...)
Old 06-02-2013, 03:53 PM
pscook's Avatar
I can't believe it's been a year and I still have NO idea what I'm doing with my suspension. As part of my annual service, I have stripped the bike down and cleaned everything. That means that I pulled the shock spring and cleaned everything up and am ready to put it together. Here's where I need some advice-
Spring- it's a 5.0 spring. I weigh 160 without gear (verified this morning, lowest weight since, well, let's just say since the Transformers were still a cartoon. originally my preload was set at 14mm and sag was whatever it was that was in the range. As I have the bike in pieces (and I lost 23 lbs since I got the bike), I might as well set a new baseline. Do I set the preload as mentioned for the Sachs in the sticky, or do I aim for a different target? Is my spring appropriate for my weight? Medium C/slow B rider and RaceTech recommends a 5.1.
Phil
FAQ; Suspension baseline settings LTRace Enduro Suspension 39 04-06-2019 06:51 AM
Baseline settings please guys for 04 MC250 with 50mm marzochis and ohlins helizeb Enduro Suspension 0 02-22-2012 03:13 AM
2005 baseline settings stay_upright Enduro Suspension 0 01-26-2009 08:37 AM
EC300 Baseline settings Magellan Enduro Suspension 7 08-26-2006 06:30 AM
