Old 01-15-2013, 01:56 PM
brider brider is offline
Default Looking for GENERAL tire advice, what kind of compound?
I have an '06 EC 300 sitting in my garage that I've only ridden around the yard (1) time with no front brake before the snow hit. I got it from a guy in Texas who raced it.
I live in CT, typical northeast terrain.
The bike has a Maxxis Cross Maxx SI in the rear, and a Cross Maxx IT in the front. both tires have the sharp edges worn off, but lots of knob height left.
According to literature by Maxxis, the SI rear should be a soft/intermediate tire, and the front intermediate.
What scares me is that both tires FEEL hard as rock, and I thought a soft/intermediate tire (meaning for soft, intermediate terrain) should have very pliable knobs; I'm afraid that this old man will get on this thing after not having ridden for 20 years and instantly wash out the front end or spin out the rear, because the knobs are too hard and not hooking up.
Will old age harden the rubber?
Do I have it backwards, that soft, intermediate terrain should use a hard-as-rock tire?
Someone please educate me, and not just endorse their fav tire without explanation as to why my "soft" tire feels rock hard to the touch.
Old 01-15-2013, 03:05 PM
Rick's Avatar
Rick Rick is offline
Maxxis have a very stiff sideway, generally very little flex. They are a very long lasting tire. I have used that combo before with good results here in my area. With that combo I can run lower psi due to the stiff side walls and not be too concerned with getting a pinch flat. Tires are like women.....everyone has a different taste What works for you, might not for the next guy.
They could be stiff from the cold temperatures as well?
Good luck, be safe!
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
Old 01-15-2013, 03:37 PM
Anders's Avatar
Anders Anders is offline
Tires will age, and older tires have harder rubber and less grip than a new tire of the same rubber compound.
You have got it right, a "soft" tire should feel softer than a "hard" tire. This refers to the rubber compound, not the terrain type.
Generally, a soft tire offers better grip (on slippery surfaces) but wears out quicker.
The tire will start loosing some of its grip as soon as the edges of the knobs gets rounded. It does not really help that the knobs still have their height if they are shaped like a dome.
To regain some traction from a worn tire some cuts the knobs back to a "sharper shape" using a hot knife or similar.
Another trick to use a (rear) tire after it's starting to wear out would be to turn it around to use the "other side" of the knobs.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 01-15-2013, 05:07 PM
pscook's Avatar
pscook pscook is offline
What I have read from different sources is that a "Soft Terrain" tire has a harder compound and sidewall to allow the knob to "pierce" the dirt, and the "Hard Terrain" tire is softer to conform to the harder terrain. This means that the label on the tire is inverse to the pliability of the carcass. An example is a trials tire, which is inherently soft and pliable, but absolutely sucks in mud and clay; yet a hard knobby is great in the loose dirt and sand. You wouldn't use a paddle tire on exposed rocks, just like you wouldn't use a trials tire in sand.
Here's some info from Michelin regarding their "soft terrain" tire, the S12:
Excels in a wide variety of conditions from soft mud to loose dirt
Rigid sidewalls for superb rider feedback
Exceptional traction on soft terrain, with tall, narrow knobs for penetration
http://www.michelinmotorcycle.com/index.cfm?event=S12XC
And here's a blurb from the Trials Competition model:
Soft rubber mix for exceptional traction
Supple casing for shock absorption
Available X11 radial rear tire provides remarkable grip in difficult conditions
Recommended pressures for trials use: 6 psi front, 5 psi rear
http://www.michelinmotorcycle.com/in...ialCompetition
Phil
(New bike pending...)
General Performance mods. Dude Enduro Engine - 2 stroke 11 02-19-2011 12:53 AM
General update on my 450 FSE cal_tony Enduro Engine 4 stroke (including EFI & Exhaust) 7 12-10-2008 10:58 AM
Tire stand for moose or tire balls kim Enduro Other... 6 12-28-2007 12:12 AM
04 gg200 / general gg questions Blowtus General Discussions & Announcements 0 07-27-2007 06:35 AM
what kind of oil dukbil Enduro Engine 4 stroke (including EFI & Exhaust) 2 03-13-2007 07:33 PM
