013 300 fr ttx rear mar 48 cc suspension set up help
iv now ridden the bike three times first was at a rutty gravelly sandy bovington felt to stiff so i backed the hs and ls right of on the ttx and the ls rebound and preload on the fork .next ride loamy sandy woodland not over used so nice going felt good if a little firm next ride tite woodland lots of tree roots far to stiff . im 75 kg no gear 52 rear 4,2 front std oil level . going to try 4.1 front 50 rear iv got the next softer setting chart for the ttx is that the way to go? not had time to service the inner cartridge on the fork thanks
There is a long thread here on the Marzocchi Pfp 48 fork. It discuss adjustments and also different oil viscosities, shim stack changes etc
I suggest you start there. http://www.gasgasrider.org/forum/showthread.php?t=11075 Sent fra min E5603 via Tapatalk
2013 rear suspension | Malcolm | Enduro Suspension | 2 | 02-12-2013 03:06 PM |
2013 GasGas rear suspension | Malcolm | Enduro Suspension | 15 | 12-18-2012 06:26 PM |
Rear suspension riding low and hard on a 07 ec 300 | jarrodw | Enduro Suspension | 9 | 12-17-2011 04:37 AM |
Rear suspension creaks | Larsa | Enduro Suspension | 9 | 09-08-2011 10:16 PM |
How many O rings on the rear suspension rocker | stay_upright | Enduro Suspension | 7 | 01-15-2008 08:58 AM |
