Old 09-13-2015, 12:12 PM
krazy's Avatar
krazy krazy is offline
Default Piston exhaust port bdc pic
Howdy,
After my tuner did the porting and head work i never bothered to look at piston height at bdc. It might actually go a hair lower than the pic, but would this be considered as good as flush or is there more top end to be had. Two green gaskets used, i assume gasgas oem ones, .3mm each.... uploadfromtaptalk1442164212333.jpg
Sent from my SM-N910F using Tapatalk
2001 EC300, mild porting and head work, DEP silencer, EC200 CDI
Old 09-13-2015, 01:12 PM
Moto7man Moto7man is offline
Mine is just a little lower than that. I am running a single .5mm oem gasgas gasket.
―Comedian Lewis Black
-Unknown Sardaukar
Old 09-13-2015, 04:01 PM
I could have taken you a photo if you posted yesterday. Had my pipe off for vibey O-rings.
I run a single 0.5mm and have some piston above the port. Not as much as in your pic though. The dyno simms that TSP ran for me back when I first modified my 2010 model showed a much more usable power curve this way rather than gaining a little at peak RPM and giving up a whole lot in the mid range.
Old 09-13-2015, 04:48 PM
I just did my topend and this is the build thread. See the photo on post 7 on this thread.
http://www.gasgasrider.org/forum/showthread.php?t=19892
-Unknown Sardaukar
Port Timing farmerj Enduro Engine - 2 stroke 8 08-15-2012 06:44 PM
exhaust port timing stainlesscycle Enduro Engine - 2 stroke 0 10-17-2011 01:26 PM
ec 300 sub port Gasgasogeros Enduro Engine - 2 stroke 13 10-24-2010 03:04 PM
Minor leak from exhaust port help? jetfish Enduro Intake/Carburetion - 2 stroke 5 12-24-2009 06:10 AM
FYI, check BDC piston/lower port clearance. socalscott Enduro Engine - 2 stroke 3 11-26-2008 01:43 PM
