Old 10-25-2015, 08:50 PM
McNut has a set of black wheels for sale also.
Sent from my iPad using Tapatalk
Old 11-05-2015, 09:56 AM
FDB's Avatar
FDB FDB is offline
Got me a set of wheels. Too much effort finding rims in South Africa
Sent from my GT-I9500 using Tapatalk
Old 04-30-2018, 02:08 PM
I'll post in this. I broke my hub racing yesterday. So I'm thinking I will lace up my spare hub. Then I started looking at new rims. Man they are expensive and I haven't yet found the Excel rims that are supposed to work.
Anybody ever polish rims? I could polish mine up and either spray them or maybe even anodize them. I'll inspect them closer to make sure there are no dents etc.
I have experience building wheels so I'm not worried about that. Any idea what length spokes for the front? I like the excel stainless spokes with the spline drive.
Matt
1999 GG EC 250 Six Days
1999 Cagiva Gran Canyon
2001 Aprilia Falco
Old 04-30-2018, 10:56 PM
Moto7man Moto7man is offline
Call Excel USA 760-732-3161,and ask for tech assistance. They will tell you exactly which model rims work and they will give you the part number which vary one digit according to color, then start shopping using the part number. I bought excel rims for my 94 CR 250 and I am buying another set for my 84 RM 250 restoration. It?s around $170 for the front and $200 for the rear. I have a truing stand so I lace and true them myself, no biggie. Good luck!
―Comedian Lewis Black
-Unknown Sardaukar
Old 05-01-2018, 07:38 PM
gasgasxc gasgasxc is offline
I have to agree with some of what's been said alredy.
Buying used complete wheels makes a lot sense.
The cost of the wheels and spokes these days has made that option quite expensive.
Lacing the wheel and truing the wheel not really a big deal but still takes some time.
Every wheel I've ever built using Buchanan spokes also had to have the spokes ground down.Skinny wheeled.Whatever.Fit for length.
It turns out to be a lot of work, time and expense especially considering they are usually going on an older bike.
New is cool but honestly if you are riding the bike a lot and changing tires a lot the newness is gone pretty quick.
And I've bent EVERY Excel wheel I've ever had.
The Buch spokes hold up well if you get the heavy duty spokes.But they aren't cheap.
Figure 4-5 hours to rebuild the wheel by the time its all said and done.
Old 05-03-2018, 06:30 AM
Default Which rims lace up to GG hubs?
Does anybody know the length of spokes?
I’ve never used buchanon. I like the excel spline drive nipples
I won’t buy a used wheelset if I can help it. I like to build wheels and most of the used sets I have bought have several seized spokes.
I know I’ll spend more money but I’ll be far happier. Also I know the tech article on this site says to heat the hub with a propane torch remove the bearings. I’ve never done this before, ever until now. I want to powder coat the hubs and doing that with a torch will affect the finish. I assume you can remove and install bearing without that. I usually stick them in the freezer anyway.
Matt
2001 Aprilia Falco
Old 05-03-2018, 02:12 PM
Excel does not make spokes for gasgas. Just Buchanan.
The excel rim part numbers are as follows
Front (silver)- ICS434
Rear (silver) - FES433
Does anybody know the torque of the nipples?
Matt
2001 Aprilia Falco
Old 05-03-2018, 03:35 PM
Also does anybody know if there are complete wheelsets that will swap over? I can get KTM wheelsets cheap.
Matt
2001 Aprilia Falco
Old 05-04-2018, 07:19 PM
I the excel spline drive spokes they look cool.
-Unknown Sardaukar
Old 05-05-2018, 12:08 AM
Some KTM wheels will swap over depending on years and whether your talking front or rear.Some years they used a common fork basicly.
In some cases the axle diameters will be different but that is easily solved by getting different bearings for the wheel.You just mic the hub(od of bearing) and the axle shaft diameter you are using(inner bearing diameter) and then the width.
Any big bearing supplier will have the bearings and seals you need to build the wheel up or you can get them.
You'll have to match seals also.
In some cases you'll have to custom some spacers for width.
The wheel may not line up with the sprocket and caliper.
Basicly as long as the width measurement from the sprocket to the rotor on the replacement wheel is the same or very close to the same as the stock wheel then you can make it work.
You can also beef up the bearings in the wheel in some cases (I highly reccomend it on rear wheels) by going wider.Their is a lot of things you can do there.Depends on the hub design on what you can get away with.Its tricky but you can usually get a little extra bearing width.
We did it on rear hubs on big bore bikes back in the day.
You couldn't keep rear bearings in the old CR 500s and KX 500s for very long so we had to mod those.
You can usually save a lot of money and time going to bearing and seal distributer over the dealer to get your bearings and seals.
You can get most of what you need if you have the old bearings and seals and or a good set of calipers.
Especially if you have a problem and need to get the bike put back together quick.
Complete Wheel Set - Red Hubs/Black Rims mcnut Parts 12 02-12-2016 11:32 AM
bearings / hubs Stoby Enduro Chassis & Body 5 05-03-2013 08:12 PM
AJP Hubs commando Enduro Chassis & Body 0 07-23-2012 08:36 AM
Gasgas white hubs, silver rims?? Keg General Discussions & Announcements 30 06-17-2011 08:31 PM
