Old 07-22-2022, 06:42 PM
swedish swedish is offline
Default Gearbox problem after rebuild
Hi guys
Long story short, bought a 2006 EC300 last year that had power like a scooter. But thanks to this forum i changed the needle and some other things, and wow what a bike it turned out to be. Spent more time on the 300 than i did on my R1. Everything went well until the end of the summer when it seized both crankshaft bearings. Now i have rebuild the engine and changed every bearing and seals, but it has even more problem now..
The plan was to start it for the first time in a year tonight.
I can't shift. It is in gear but i dont know which, and nothing happens when i pull the lever.
I also noticed that the kick starter don't return to the normal position. When i lift the kick lever up i can hear it click. I can kick start the bike but need to manually move up the lever.
I checked the service manual and took the time to make everything right. At least i thougt so. Unfurtunately i must have missed something.
I have filled the engine with oil, but no oil in the clutch yet. Is it important to fill and bleed the clutch before i could change the gears?
Anyone with the same problem? It would be great if it could be solved without splitting the engine again 🙈
Thanks!
Ec250 Clutch/gearbox problem Banwen Enduro Engine - 2 stroke 5 12-18-2020 12:41 AM
GG EC 300 '01 - Rebuild // Powervalve problem Hugo4x4 Enduro Engine - 2 stroke 6 06-14-2017 07:10 AM
Just picked up an 06 with a gearbox problem. shang General Discussions & Announcements 12 02-16-2016 09:33 AM
Who can rebuild a FSE 450 starter? Video with problem olderandyzer Enduro Engine 4 stroke (including EFI & Exhaust) 6 12-22-2014 04:23 PM
Front sprocket problem after rebuild .... Packman Enduro Engine - 2 stroke 2 03-15-2014 06:18 PM
