Old 09-11-2017, 05:38 AM
Anders's Avatar
Anders Anders is offline
Originally Posted by 3beejay3 View Post
What is the process to remove the adjuster/spring and floating piston assembly?
It has now broke again. I now have some replacement parts to fix the PFP, but am wondering at how much of a process it is to remove the adjuster/spring/floating piston assembly??
Does the whole fork have to come apart to facilitate removal, or can the PFP assembly be removed just by unscrewing it from the top of the fork?
The manual doesn't seem real clear on this to my eyes, as it only covers oil/seal/bushing replacement and a few other items.....
You can take out the complete compression valve assembly with PFP, etc from the top. Just remove the leg from the triple clamps and unscrew it. I usually loosen the top triple clamp, loosen the compression valve assembly and then remove the fork leg. Easier that way than to clamp the complete leg in a vise.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Cartridge inside of fork Bailey28 Enduro Suspension 11 06-27-2015 07:26 AM
2013 cartridge air filter. roostafish General Discussions & Announcements 15 03-08-2012 02:16 PM
Ohlins TTX Cartridge kit for 300 09 snaissidis Enduro Suspension 0 11-08-2009 03:17 AM
50mm duel cartridge-totally ignorant mattmax Enduro Suspension 1 12-10-2006 05:24 PM
