Old 09-28-2015, 09:27 PM
Moto7man Moto7man is offline
I assume you dump the fluid at temperature as well, and put room temp fluid back in. Also adds to a significant variance in viscosity.
Jacobi,
Good point and Me like the shiny pictures,thanks for posting.
―Comedian Lewis Black
-Unknown Sardaukar
Old 09-28-2015, 10:29 PM
And to be honest, I've never watched the sight glass. 900-1000ml of fluid into the cases. None leaks out. Never felt the need to cross check against the sight glass.
Dump the oil, transfer back into an old bottle. Make sure same volume comes out - good to know the bike isn't using oil (main seal failure).
Repeat.
Old 09-29-2015, 08:46 AM
GasGas's Avatar
GasGas GasGas is offline
Is there not a oil passage right beside the drain plug?
2018 EC 300
Old 09-29-2015, 04:40 PM
barossi73's Avatar
mine does this too,drains fast,comes up slow on the sight glass.A lot of engines do this 'to a degree',eg.my wife told me her car oil was low when she checked it hot,by time i checked it cold later the level was fine.most engines only need a couple minutes though!anything with dry sump must be checked cold or you'll find they read low for up to an hour or more also.
2013 ec200r
Old 09-29-2015, 05:17 PM
There probably is one right where the drain plug is, but I'm not seeing it in my pics.
From this side it appears there could be one, bottom left, right of where the shift shaft goes.
But from this side I'm not seeing it (likely hidden behind the actual drain plug).
Even if this is the case, same logic applies. Cold thick fluid being added to that side and having to bleed through a somewhat restricted orifice to make its way across and self level vs dropping thinner warm/hot oil back out.
Strange issue. Need advice. FDB Enduro Intake/Carburetion - 2 stroke 6 07-20-2014 03:04 PM
oil Fill plug. 2001 EC250 Dirt Dawg Enduro Engine - 2 stroke 6 04-23-2014 06:47 PM
Strange spots on piston nokturnal Enduro Engine - 2 stroke 9 11-17-2013 11:57 PM
12 300 running strange shark4465 Enduro Engine - 2 stroke 21 01-05-2013 08:20 PM
Drain and Fill Dude Enduro Engine - 2 stroke 1 04-24-2011 06:21 PM
