Old 05-06-2018, 06:32 PM
hadfield4wd hadfield4wd is offline
This is the existing bearing and spacers.
I’ll reuse my spare hub and lace up the rim. I need to check it for major damage. Which I think is ok. Only a small dent and usual scrapes.
I am powder coating the hub. I removed the bearings without heat so thats what I’ll continue to do.
I don’t like the current setup.
I’ll get a bearing with the ID of the axle. And have custom spacers made.
Matt
1999 GG EC 250 Six Days
1999 Cagiva Gran Canyon
2001 Aprilia Falco
2001 Triumph Speed Triple for my 20 year old
2000 GG XC250 for my 20 year old
2003 Honda Rancher 350 for the wife
Old 05-06-2018, 07:29 PM
gasgasxc gasgasxc is offline
You cannot eliminate that internal spacer.
IDK what you mean by not liking the current setup.
But you have to have that spacer floating in there.
Old 05-06-2018, 08:45 PM
I’m not eliminating the internal spacer. I know its needed for preload. You notice the shoulder? It goes in the ID of the bearing. Making the ID 17mm for my axle. I’m going to get a bearing that has a 17mm ID. That shoulder on all the spacers pressed into the bearing is a pain.
I’ll make an internal spacer without the shoulders. This will make bearing changes easier.
Its hard getting my point across on a forum. Thanks for the input.
Matt
2001 Aprilia Falco
Old 05-06-2018, 09:55 PM
Let's see.
Should be able to use the spacers you have.
Just mill them back to where the taper starts.
Or turn them down on a lathe.Right?
Old 05-07-2018, 11:27 AM
Originally Posted by gasgasxc View Post
Let's see.
Yes I could turn them down. I want to keep those spacers just in case.
I have access to a machine shop at work so the spacers are no big deal. One of my machinists can whip those up from stainless scrap during lunch if I want.
Matt
2001 Aprilia Falco
Old 05-08-2018, 05:03 AM
RBrider's Avatar
RBrider RBrider is offline
Is this for your '99? I'm not certain, but I believe I have the long end spacer (bottom of your pic) at the house in NC. I plan on being there by this weekend.
If you want it, it's yours for postage. I got it by accident back when I was replacing the wheel bearings on my '01.
The ID & OD are the same from '99 to '01, but the length is different.
RB
Old 05-17-2018, 01:46 PM
RB
Sorry for the late reply. Yeah I'll take it. I'll shoot you a PM.
Mine is a '99, but I don't have stand 'zooks, I have WP extreme's 50mm conventionals. 17mm is the axle diameter.
Matt
2001 Aprilia Falco
Old 05-18-2018, 07:49 AM
Also does anybody know the torque specify the spokes?
Sent from my SM-G960U using Tapatalk
Matt
2001 Aprilia Falco
Old 05-18-2018, 02:17 PM
48 in.lb is pretty much the accepted standard today.
You can only get accurate spoke torque numbers with pristine components.
It really comes down to feel and constant adjustment until they stay snug and the wheel stays true IMHO
Old 05-19-2018, 07:02 AM
Great thank you. New spokes and rim on the way.
Matt
2001 Aprilia Falco
Complete Wheel Set - Red Hubs/Black Rims mcnut Parts 12 02-12-2016 11:32 AM
bearings / hubs Stoby Enduro Chassis & Body 5 05-03-2013 08:12 PM
AJP Hubs commando Enduro Chassis & Body 0 07-23-2012 08:36 AM
Gasgas white hubs, silver rims?? Keg General Discussions & Announcements 30 06-17-2011 08:31 PM
