Wath can I do to change the color of spark plug
Bike: ec 300 2008 jetting:42,N3CG@4 ,180 main. temp: around 20c-27c. Motorex crosspower 50:1.
Bike runs good,start very good,idle good.all ways looks like that. Lean or rich? Looks lean to me but with this settings I'm not so shore. |
Ignore it, you are not learning anything from that picture.
It is well conceivable that an engine could be rich on closed throttle, lean on 1/2 throttle, and rich again on open. Reading a plug in an uncontrolled experiment will draw no reliable information. Long straight, wide open for long time, pull clutch, kill engine. That will give a clue about the main, but otherwise forget just looking at the plug. Really most useful for road racing.
'07 EC300 GG '14 TXT250 GG '? 496 CPI Cheetah RZ/RGV hybrid '22 765 Street Triple RS '21 XTrainer '69 Stinger T125 Suzuki '23 TRS 250RR (it's a Trials thing) |
The outer electrode should show a colour change in the middle 2/3 if heat range is correct,a plug with more hours on it gives an overall indicator and also colours quicker if you have made a jetting change.also some oils skew the colour.should be a fine white ring on perimeter of center electrode face if ignition correct.deep down the ceramic core should be a discoloured ring,not white/grey (hard to see without cutting threads off)
Otherwise it varies as stated above depending on your last ride.
2013 ec200r |
plug color and questions | BryanMcc | Enduro Intake/Carburetion - 2 stroke | 4 | 04-11-2014 01:05 AM |
Spark plug | eviljim | Enduro Engine - 2 stroke | 4 | 01-06-2013 02:35 PM |
Spark Plug Gap | savage sausage | Enduro Engine - 2 stroke | 3 | 04-15-2012 11:54 AM |
spark plug help ec 125 | rmlt2008 | Enduro Electrical & Wiring | 5 | 09-16-2011 11:35 PM |
Spark plug | gasgas125sm08 | Enduro Engine - 2 stroke | 0 | 03-08-2010 09:42 AM |
