Old 05-20-2016, 05:48 AM
Still pulled apart..
Forks disassembled, cleaned, little shuffle to the mid comp.. and mostly back together. Just need to add oil!
Shock pulled, cleaned, and serviced. Just needs a spring to be put back on.
Linkage bare! Awaiting new needle rollers, seals and bushings.
Swingarm pivot and bearings cleaned and lubricated.
Headstem bearings same as above. Clean nnn lube!
Airbox cleaned, few bolts replaced, some running repairs where the subframe had started to flog out. Awaiting silicone to seal up the gaps in the airbox again.
New front sprocket fitted!
New front pads on the ready!
That is all!
Except I have also worn right through the plastic sleeve for the front brake line. Will need to line up a replacement soon, before she starts wearing through the coating and into the braid.
Rear disc has seen some better days too! Better get one of them ordered.
Why do kms wear things out?
Old 05-20-2016, 02:15 PM
Hooligan Hooligan is offline
I am trying to put new grips on but I discovered that the GasGas 250 4T has an odd sized throttle tube cam and I'm not sure where to get one.
The throttle tube I have is cracked and I'd like a spare just in case. Of course GasGas doesn't list just the throttle tube, only the complete throttle assembly for $104, which is a bit much.
It appears that the throttle tube is the same as a KTM 4T model but not 100% sure on that.
After all the mechanical work I've done recently I decided to give the bike a bit of a face lift
Out with the old 08 front
In with the '11
I'm really pleased with the look, one I learn how to remove the front wheel , I'll put the nice new white fork guards
Old 06-13-2016, 02:43 AM
Anders's Avatar
Anders Anders is offline
Did a race on Saturday. Great fun. Crashed on a nice, round rock. RHS radiator got banana shaped but no leaks. I know, I should have bought some radiator guards earlier...
I ordered a set from Bulletproof Designs just now. Better late than never I guess.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 06-13-2016, 04:29 PM
YouTube will show you how (shockingly) easy it is to straighten a radiator if you take your time about it
2003 txt250 Pro
2013 Ossa 280i
Old 06-14-2016, 01:10 AM
Anders's Avatar
Yep. Found a video showing the tecnique. I guess I'll try it out, but I'm afraid it will start leaking if I knock it around too much. I think it will fit within the radiator guard as it is, but we'll see when the Bulletproof ones arrive in 2-3 weeks.
Anders
1986 Duc Mille S2
etc
Old 06-20-2016, 04:22 AM
Olliesherman Olliesherman is offline
well i have spent the last 3 hours of work today and 4 hours of work friday reading this entire thread.
loads of great ideas on here for me to do to my 2009 ec 300 just hope i have a job left to pay for them all haha
Old 06-21-2016, 02:05 AM
mtnmanseth's Avatar
mtnmanseth mtnmanseth is offline
-Installed new Nachi rear wheel bearings, seals, and Checkpoint wheel spacers (thanks for install directions for that weird aluminum washer!)
-Repacked exhaust
-Spooned on a new rear tire
-Changed tranny oil w 900 ml Rotella 15w40
-Installed new Checkpoint oversized power valve cover
-Fresh Engine Ice coolant
-New Pillowtop grips
-Installed thin rubber floor matting to top of skid plate (to attenuate engine noise)
-Rejetted for 5k'+ elevation
She's ready for a 1,500 mile roadtrip to Idaho for the Klim Cow Tag ride!
2005 GasGas EC300
2017 Beta 300RR Race Edition
2021 TM Racing 300EN Fi (2T)
Old 06-22-2016, 08:11 AM
Where did you get the powervalve cover from I really want one but everyone I found is out of stock
Old 06-22-2016, 08:25 AM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
Have you tried Les Tinnius for the pv cover? Les made the first commercially available ones for us.
http://ltracing.com/
If Les Tinnius is out of them, they are listed on Matt Stavish's web site. They make some great accessories for Gas Gas. (Matt used to be a GasGas factory off-road rider for the US National enduro and hare scrambles.)
Look on this page.
http://checkpointoff-road.com/store.html
Good Luck and Good Riding!
Jim
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Old 06-22-2016, 08:43 AM
Oh dear there is some really nice bits on there I want
DNF today Pepperami Enduro Chassis & Body 6 09-18-2013 11:59 AM
Got my first GG today! RonMexico General Discussions & Announcements 6 02-19-2011 12:39 PM
Went Riding Today and..... coolum74 Enduro Engine 4 stroke (including EFI & Exhaust) 2 11-30-2008 01:12 PM
HELP! I tried to use my gasgas as a jet ski today! sammyj18 General Discussions & Announcements 19 11-21-2008 08:01 PM
SHNF From Today Boomhauer Pictures & Videos 13 10-30-2007 04:18 PM
