Old 02-10-2019, 08:02 PM
SS109's Avatar
SS109 SS109 is offline
Pretty much it has to be the shifter return spring, detent spring, or the kick start return spring. If it isn't one of those then I would say a foreign object somehow got in there. Regardless of what it is, time to get the dealer to make it right.
WildAzzRacing YouTube channel
AZ State Parks OHV Ambassador
'11 EC250R
'98 KDX220
Old 02-10-2019, 08:31 PM
Zman's Avatar
Zman Zman is offline
If it was one of those springs, there would be an obvious functional problem with the bike and that does not sound like the situation.
Old 02-10-2019, 09:02 PM
Greatdane Greatdane is offline
Could it be the power valve linkage retaining clip? The one that holds the socket on the actuator arm to the valve pin?
Old 02-11-2019, 01:15 AM
Anders's Avatar
Anders Anders is offline
Yep. I agree. It could.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 02-11-2019, 04:53 AM
Harty89 Harty89 is offline
I think you might be onto it. ME72326GG-CEQ-1 the security clip looks like a likely candidate. The importer has been forwarded my photos so we'll see what they come up with.
Old 02-11-2019, 07:03 AM
Zman's Avatar
I think the diameter of that wire is very small. Maybe 1mm +/-
Old 02-12-2019, 06:14 PM
Can confirm that it was a powervalve linkage pin. However, it was not the one that was installed onto my powervalve.... It's still in place.
Further to this the one that was in place wasn't installed correctly!!! If you've got the exhaust off I'd recommend popping the cover off and checking that the top of the clip is pushed back up into the hole in the socket.
Old 02-13-2019, 02:10 PM
Gasser Nate's Avatar
Is there one at the other end of the power valve arm as well? Behind the inner clutch cover?
Old 02-13-2019, 02:39 PM
Just bolted at the bottom and ball and socket at the top with this clip to secure the socket.
Tire Debris - Michelin with Tubliss Neil E. Enduro Chassis & Body 5 08-29-2017 11:05 AM
Hot Wire Smell ?? StuJohnson Enduro Electrical & Wiring 2 06-16-2013 10:33 AM
white wire bonkeye Enduro Electrical & Wiring 3 04-29-2013 11:54 AM
Help. Little black wire Hicksi Enduro Electrical & Wiring 12 08-19-2011 02:11 PM
No Yel/Blu wire effect. cal_tony Enduro Engine 4 stroke (including EFI & Exhaust) 8 01-12-2009 10:29 AM
