Old 04-19-2019, 02:48 PM
schlitzy schlitzy is offline
Default 2009 450fsr sachs shock rebuild kit
Anyone know where I can get all the parts to service a Sachs shock on a 2009 450fsr? In the States if possible.
Thx
Old 04-22-2019, 08:35 PM
rvktm rvktm is offline
i used a skf seal block on a 010 two stroke one or look to see if racetech do a block did look at fitting a different seal to the std block showa kyb wp use the same seal on there 18 mm shock good luck
Old 04-23-2019, 06:04 AM
Thx
The sachs seals are pretty resilient.. Is yours actually leaking when under full pressure? How does the shaft look?
Getting a seal or complete seal head for a Sachs can be a pain in the ringbit... Most tuners will mill the stock seal head to take a KYB/Showa seal, otherwise SKF do a complete seal head. You just need to be sure on which one you need. Sachs use 16 and 18mm shafts.. some use top out spring assemblies, while others have a bump stop on the seal head. Few different height seal heads getting around too!
2009 450FSR valve specs schlitzy Enduro Engine 4 stroke (including EFI & Exhaust) 2 04-07-2016 08:46 PM
2009 ec300 sachs suspenders Diggs345 Enduro Suspension 8 04-27-2012 01:08 PM
2009 SACHS Shock Question 300XCRider Enduro Suspension 4 02-16-2011 07:59 PM
Sachs shock rebuild. nick790 Enduro Suspension 1 05-31-2010 09:52 PM
