15hrs on euro spec 300r
Thought I'd give my experience with this bike so far
Likes: Motor, heaps of mumbo and when mated to the Suzuki needles easy to use, good fuel economy and hard to stall. The slightly lower flywheel effect of not having the ring gear is nice as the bike is punchier but still tractable. A 10oz fww would turn it into a dozer. Suspension and handling, you can get way out of shape on this bike, and smash through stuff that I wouldn't before, it's not as super agile in vv tight stuff as the old frame but it is well and truly good enough. Seems really well balanced especially brake sliding. Seat. It's got a nice shape and works well. Brakes. Well and truly powerful and progressive, Really like. Hubs wheels and spokes, they are nuclear proof This bike is very easy to work on and is way better than the old bike except for carby access. Forks. Very very good forks that give confidence to start doing stupid stuff, and a very easy to own as well due the bottom nut setup that should be law on all twin chamber forks. Grip. It has a level of grip that my last bike just didn't. Suzuki level grip front and rear. Unlikes. Clutch, it moans and sqwaks, which just sounds bad, it never does anything funny and could be fixed with a new basket from an aftermarket company but I've never had this on any other bike. Renthall twinwalls, I understand the need to not break your bars in a race, but they are just so stiff. Powder coated swing arm, with powder coating coming off. Chain rattle still. Q stealth spooges no matter how good your jetting is. BUT it's very neighbourly and it's just some oil. Freakin side stand, every other manufacture can get this right, it needs constant care and goes straight through concrete, what is the reason for this??? Gear lever made out of solder ( I know it's better than a broken shift shaft but other bikes don't bend like yuri geller is looking at it) Multi piece rear fender, it never works out in the end. Squeaky headlight mount. Meh it's just some lazyness. Ajp clutch has no crossover levers, but works great. All in all these a pretty tame dislikes really. It's a good fun bike. Nothing has fallen off or broken spokes have needed a touch of adjustment as has the chain. I'm much happier with it than my old bike I could see myself putting a rekluse clutch basket in and seeing if I could find a bladder conversion for ohlins shocks for ease of servicing and I think it feels better, apart from that no mods needed apart from changing springs for your weight. If you live in a rock garden you might need a revalve..
Excellent Yuri Geller reference. How many under 50 get that one?
I was going to say the same thing. Must've had a subscription to the National Enquirer as well.
Over my head..
Uri Geller = spoon bending psychic.
Chain rattle: Un bolt your chain slider (careful as it's very brittle). Run a strip of stiff rubber weatherstripping where it rubs on the swingarm (top and bottom). No more chain rattle (usually chain rattling is from too low a speed in whatever gear). It's amazing how much the hollow swingarm radiates a bit of chain noise. The foam rubber I used was ~4mm thick x ~20mm wide.
2011 EC250E |
On my chain-slappy WR450, I lifted the chain slider on top of the swing arm and hit it with a few globs from the hot glue gun (others use rubber spacers and such). Chain slap is reduced, if not completely eliminated.
New CDI euro spec 300r | Simmo737 | Enduro Engine - 2 stroke | 3 | 05-26-2013 07:35 AM |
2013 race 300 Aussie/Euro spec first impressions | Simmo737 | Ride Reports | 25 | 04-05-2013 06:21 PM |
2010 euro spec 300 Race model?? | trailridernut | General Discussions & Announcements | 36 | 04-08-2011 05:33 AM |
Euro Spec vs. USA Spec EC's - What's the diff? | bondo | General Discussions & Announcements | 4 | 12-14-2007 12:12 PM |
